This problem should be removed because:
Problem with Monitors
Screen becomes unviewable
I plugged it up, and when it turns on, the picture is fine, but after a few minutes the picture starts to distort, the picture starts to get blurry as everything on my desktop display starts to move as if it was rippling like motion in water, and then the display is not readable at all. I tried to adjust the contrast and the brightness and this does not stop the movement, or help at all.
Solutions (1)
Best Solution
Sounds like a problem with the graphics card or on board video. Please state which one you have and type. The last option is a bad monitor. Try Degaussing it first on the monitors menu selections. If you use a graphics card, you can disable it and try the on board one to see if it helps. If you need further assistance, please ask. I can guide you through all the steps.
Dim Sony GDM-20SE2t
I have d sony gdm 20se2t in for repair with dim video. There is no flyback adjustment to adjust the raster. Has any one seen and solved...
i recently had to move my desk, unplug
i recently had to move my desk, unplug computer,monitor, etc. once i set everything up again, all colors on my monitor are distorted. can...
Signal outof range
Signal outof range
blurry screen on proview tft monitor
Add Your Solution
appears that mensage ''OSD...
appears that mensage ''OSD LOCKED'' every 5s,how to unable that function?
how to download mixer
MY VOLUME DOESNT WORK
Fix-O-Meter
952
952 people viewed this problem
- 1 person found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Monitor Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
