Question about Hotpoint  16.6 Cu. Ft. Top-Freezer Refrigerator
Hotpoint sidebyside--freezer back panel has ice on it.
Freezer stop freezing, until i take panel off, then i use a blow dryer to melt the ice. then i put panel back on. Freezer starts to freeze again.
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Does this have solid state control, or just the good "ol knob thermostat?
  • Mike Smith
    Mike Smith May 11, 2010
    Bad defrost heater probably . Need model number to help though .
  • 358 Answers
It could be the defrost timer the defrost heater or the defrost termostat You can check the heaters for continuity or when the freezer is all cover with ice turn the timer (located in the cold control box inside the refrigerator ) untill the compresor stops and if the heaters start glowing the timer is bad.
Posted on Jul 22, 2009
Frig & freezer not cooling enough. Ice forming in back of bottom freezer.
You need to have the defrost cycle checked.( heater, limit stat, timer) If the frig can't defrost air can't move across your coils to cool properly. To temporarily get by until you can get a repairman, use a blow dryer to melt the ice build up. Once melted it will work normally for about 2 days till it freezes up again.
Nov 13, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
Inside rear panel bulging
Unplug the unit and take out all the drawers and remove the back (behind the drawers) panel carefully. (This back panel has foamy thermal insulation behind it and this will be probably be enmeshed with ice - you may have to wait awhile for this ice to melt before you can remove the panel, even after you have unscrewed it.
When you have got the back panel off, you will see a large solid block of ice, probably halfway up the cooling coils, right down to the bottom of the exposed space. You have to melt all this ice (I used a hair dryer to blow warm air onto the ice (have towels and a bucket ready to mop up the melted water, otherwise it will run over the floor. When you have melted all this ice, you will see a drain hole at the bottom of the exposed space. This will have ice in it and it must be cleared.
Then replace the back panel and all should be OK.
The panel bulges because ice/water is accumulating behind the panel, water, when it freezes, expands, forcing the panel forwards.
I reckon it's a Hotpoint Design fault. What is supposed to happen is that during the heating cycle, melted ice drops down from the cooling coils and down the drain hole onto a plate over the compressor unit, where it evaporates. BUT, during the cooling cycle, a fan circulates cold air from the cooling coils, through the entire unit, which includes the chamber behind the panel that is below the coils. Thus this chamber gets cold (-18 deg.C) so that water dripping down during the heating cycle is frozen before it has a chance to fall down the drain hole.
I now defrost in this manner every six months or so. Sadly, very sadly, Hotpoint, like other white goods manufacturers (Baxi Potterton boilers for instance) do not reply to my enquiries.
Hope this helps.
Feb 19, 2013 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Fridge not cooling coils in freezer full of ice used hair dryer to melt ice solves problem for awhile then same again
It is a defrost problem since the ice that freezes on the freezer coils
is not being melted by the defrost system.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician butyou could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info Also check evaporator fan in freezer If this was helpful please rate me
Thanks for using fixya
IMUFO2
Leo Ponder
imufo2@sbcglobal.net"
Jul 23, 2011 | Hotpoint 14.4 cu. ft. Top Freezer No-Frost...
Why I found water at the bottom of the freezer
most likely the drain is blocked.remove the draws or bins from the freezer, you might have to use a hair dryer to melt out the ice so you can remove the bottom bin.at the bottom of the back panel there's a drain hole where the water that melts when in defrost drains down is blocked and now the water overflows on the freezer floor and sometimes out onto the kitchen floor,if you don't see an opening at the bottom of the back panel then remove the panel to get at the drain hole.melt out any ice with hair dryer,next you have to clear out the drain,i use a steemer to blow through whatever is blocking the drain,if you don't have a steemer you can try a baster or anything that will blow air through the drain,you can stick a thin screw driver in the hole and heat the metal on the screw driver and it will cut through the ice down in the hole then try the baster to blow through,when you think you cleared the drain,pour hot water down the hole,if it goes down you're done,if not keep at it until water drains down the hole,unplug the machine or shut down the control,if you don't warm air will get into the air vents and freeze up and you'll have another problem on your hands.good luck
Feb 06, 2011 | Maytag MZD2766GES Side by Side...
No air blowing into fridge, although we can hear blower. Freezer is working
if you can hear the fan still blowing but no cold air coming up to fridge section a common problem with bottom mount freezers is the door gets left open and the air ducts freeze up and the air can't blow up to the top.turn the control off in the freezer.remove the top shelf and the door,check to see if there are any screws one on each side of the slide arms,if there are remove them and lift the door up and out,with a hair dryer melt out the ice by blowing the hot air up each side of the back wall,also if the back inside wall of the freezer is covered with ice or like snow then you have a defrost problem but if there's no ice on back wall do what i said and blow the air up the sides of the back wall through the vents until no more water is seen dripping through the vent holes,then turn the freezer back on and check to see if you feel cold air blowing in through the vents in the fridge section,if you feel cold air then you're all set,if not keep blowing the hot air up the sides until it's melted out.let me know what you find,you'll know if the door was left open,ice will be on the ceiling near the light switch and sometimes on the top of the freezer door
Oct 25, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer won't freez and the bottom nearly cools
I think you need to repost or clarify. You are asking why the freezer on your maytag gas dryer wont freeze. Assuming you have a split frig/freezer.... and assuming the compressor is working.... most common problem is either the fan motor is bad or possibly seized up with ice. Also the coils may be completely iced over. You can take two approaches here... Either turn the unit off and let it completely defrost, and let all the ice melt. Also best to tilt it to drain pooled up water after it melts. Or... you can remove some panels (sometimes difficult to do), and access the fan blower and coils. Once you get to the fan blower and coils check and make sure fan is blowing. let all the ice melt. A blow dryer works good for this, or just let it sit, and again make sure you tilt it and drain any pooling water. Also you should clean all the dirt, fuzz, and scum from under the unit around all the coils, and fans behind and below the unit.
Sep 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Water accumulates in freezer bottom and of course frezzes. if we don't break up and remove the ice, water will leak out the door. best guess on the model below. The back panel states "R134a"
134a is the type of freon used. There is a defrost drain hole at the very bottom of the freezer usally below the back panel. It has a tube that runs underneath behind the back bottom of freezer section. It can get stopped up with slugg that keeps the water from getting to the defrost water pan. The water in the tube freezes and the water then runs out the front of freezer being it has no exit. . hot water or a hair dryer gun. If you have means to blow hole out after ice is melted will do a better job. Blowing warm water down hole through tube with mouth will knock ice out quickly but be very careful. also this ewill remove any trash build up in drain hole.
Mar 01, 2010 | Kenmore 57029 Side by Side Refrigerator
Hotpoint refrigerator freezer(top) mod ctx18bacerww not cooling/freezing correctly. removed inside back panel in freezer compartment,found coils partially covered in frost, fan not blowing.. flicked fan...
Hi, fan may have stuck, but you could have a defrost problem, check defrost heater, thermodisc(defrost thermostat) and defrost timer. or excessive moisture, if your days are hot, or if you put hot foods in ref. could result in excessive ice build up. you can manually defrost it, by unpluging ref. for couple of hrs, until all ice melted. then restart. you make get excessive water on floor. be prepared.
Aug 02, 2009 | Refrigerators
My frige stays warm all the time it is a Hotpoint
evaporator coils are iced up on the freezer side. either take everything out of the fridge and unplug it and let it sit for a day to defrost, or remove the inside rear panel where there is frost and (with the fridge off) use warm water sprayed on the ice to defrost it (or use a hair dryer, but just until the ice is melted. do not overheat the metal). soak up the excess water (underneath the fridge, too), and turn it on empty. let it run empty for a day to get it cold, then put the stuff back in. if the stuff is in there when it's warm, the humidity will ice up the coils again.
Jul 23, 2009 | Hotpoint HSS25GFP Side by Side...
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Hotpoint  16.6 Cu. Ft. Top-Freezer Refrigerator Logo
184 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
