I found the answer! Found and turned off the "Slow Keys" function in Settings. (General...Accessibility...Keyboard)
SOURCE: Keyboard LX501 : Function keys work but number and alphabetic keys and other keys dont
Check the underside of the keyboard and see if there is a reset button (might be a small pin hole).
If not it might be a software problem.
SOURCE: PROBLEM WITH KEYBOARD
dear,
first try with reinstalling the driver.. but uninstall the previous one completely..
if still facing the problem then it could be ur window problem.. a virus or something else..
by the way, is it work fine on notepad, ms word or word pad.. if yes, then the max. chances is that, it could be the windows problem
regards,
hope it will help
SOURCE: deactivate the zoom function on logitech mx3200 keyboard
This should help you out:
FN + pics key will mute sound for the slider on the MX 3200
FN + 'x' (close) key will disable the zoom slider and the 100% key
FN + document flip key will re-enable them
SOURCE: NewTouch Keyboard 200 function keys do not work on a MacBook Pro running 10.5
Normal
0
Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on Key Settings.
3. Then set up the keys by selecting the Key to be changed.
Hope this will help some. Bud
SOURCE: logitech wireless keyboard model number yrk49
Normal
0
Normal
0
Press the Receiver button (and the lights will start
flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT
button on the back of the board to connect the keyboard to the
receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button
on the back of the mouse to connect to the receiver. Then they
should work okay.
Hope this helps. Bud
