Question about GE 24 in. GSD4320Z Built-in Dishwasher
Ge Triton GSD5500 will not drain
Have done all the steps regarding checking drain hose to dispoer, cleaning out any debris from bottom of drain, etc. No clogs.
What's next?
rgerard
5 Suggested Answers
SOURCE: dishwasher
GE 720 Potscrubber I started with the water puddling in bottom now it progressed to leaking on the floor. I had a repair guy come to my home yesterday and he says a broken seal and my total cost to replace seal and labor is $165 plus tax.
What is the life expectancy? He did not sound too promising about the future of my dishwasher and said he is certain there will be another repair need shortly something related to the water saturating an area underneath the dishwasher?
He reccomended I call Sears and replace with a Whirlpool product. He claimed he put his kids thru college repairing GE products. My husband wants to repair and I dont because of fear of spending more money!
Posted on Apr 26, 2008
  • 108 Answers
SOURCE: GE Triton dishwasher won't drain.
It sounds like the drain pump has gone bad.
First, unplug the unit or turn of the breaker, then remove as much water as you can with a wet vac if possible.
Remove the panels from the bottom of the front of the dishwasher (removing the big door won't help you) Then, disconnect the drain hoses from the pump (squeeze the hose clamps with pliers), any remaining water will come out when you do this, so you might want to put a thick towel underneath.
Pull out the wires—use pliers so you don't yank the wires out of the plugs, and remove the pump. Look inside and make sure there is nothing stopping the propeller- you may need to unscrew the pump from the plastic housing check.
If there is no blockage, it has likely just "gone bad" but to do one last check: take an old, two wire extention cord and carefully connect each wire to one of the prongs on the pump (make sure no stray wires "dangle" by using electrical tape if you need to) and plug it into a wall outlet.
If the propeller spins, something else is wrong with the machine but if it doesn't, you need a new one.
Posted on Apr 09, 2009
  • 4 Answers
SOURCE: My GE TRITON XL dishwasher doesn't drain
I've had this problem too, and fixed it by cleaning the lower drain basket. But it could also be your pump or drain hose is clogged. To clean the drain basket, I removed the lower rack and spray arm. To remove the spray arm, turn it counter clockwise while gently lifting it up. There's a lock ring that will also need to be removed. (Remember how these parts come off and in what order.) There is a vertical tube that is attached to the upper and lower spray arms that is secured by a hex-screw that you will need to loosen and disengage from the lower spray arm. After this, you can remove the small protection grid then reach in and clean out the gunk from the basket. I ran a rinse cycle to see if it did the trick and sure enough, it now drains. By the way, I am NOT a professional.
Posted on Dec 11, 2009
SOURCE: my GE triton dishwasher has water standing in the
The GE GSD5500 has a check valve in the rear of the unit under the FILTER FRAME that screws in. GE part WD24X10018.
The white rubber stopper wears out and lets water return to the tub!
Remove filter frame (4 screws) and unscrew the check valve to replace. Try appliancepartspros.com for part # AP2617344.
Posted on Dec 28, 2009
GE Triton dishwasher occasionally won't drain all the water..still in bottom of dishwasher or leaks into floor. Not every time!
make sure that a portion of the drain hose was hung higher than the connection to the garbage disposal. hose should not have kinks or twists. if that doesn't work, clean (no clog) or replace drain hose.
Oct 07, 2015 | GE Dishwashers
I have a ge profile washer machine washes and spins but wont drain
Hi.
Disconnect power, then locate the access to drain pump. On GE top loader the pump access is usually at the back, sometimes at the bottom. Disconnect the hose from the pump and remove any blockage in there.
Check also the height of the drain hose at the back and ensure that the hose is set according to manual. An drain hose set incorrectly will result in drain problems.
If that does not fix the problem, clean or replace the pressure switch and pressure hose that detects water level determining when to start and stop draining.
Regards.
Ginko
Jul 08, 2011 | GE Profile WPRE8100G
I have a GE Triton XL Eterna Series dishwasher that is not draining. Can you help me diagnose the problem? Some people have told me that it is the pump, while others say it is the motor or drain hose.
Have you checked to see if there are food particles that might be obstructing the drain? Check the bottom center of the unit, there should be a filter, it might be clogged.
Feb 17, 2011 | GE Dishwashers
GE Triton 24
Hi
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please post back for any further assistance.
Daniel
Jul 23, 2010 | GE Dishwashers
My GE triton dishwasher has water standing in the
Nov 30, 2009 | GE Dishwashers
Water leaking from bottom, lots of suds.
Hi
Thanks for using FixYa. This may happen due one or more than one of these issues with your washer--
Probably there is something(coins, socks, dirt, debris, etc) stuck inside the drain filter of your washer. You'll need to check the drain filter. To access the drain filter. To check the drain pump follow these steps:
Unplug the washer to completely disconnect electrical power.Remove the bottom front service panel as shown in the first image below.
Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
This issue can also be due to clogged drain pump or drain filter, due to which the hose have developed leak. This will cause suds
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Sep 22, 2009 | GE Washing Machines
Profile triton
Could be your pump and drain hose but first I would check the drain hose. There is a drain hose for your dishwasher that often gets clogged. Remove the drain hose and clean it out. reinstall the hose and your dishwasher will drain. The dishwasher should have a panel to remove and then comes out easily, just be careful not to pull it out too far. If this does not fixya then you may need to throw some parts at it, but hopefully not. Good luck
Jul 11, 2009 | GE Dishwashers
GE Triton dishwasher will not drain and after cycle.
Look at the timer to see if the contacts have finally worn off. The circuit board may have failed too.
Nov 09, 2017 | GE 24 in. GSD4320Z Built-in Dishwasher
Ge Triton dishwasher will not drain and makes a funny noise.
Yes!! The crackling noise you hear is small pieces of food stuck spinning around the moter drain....All you have to do is find the drain hose (some are located under the sink of the kitchen) disconnect it from the draining source (not the back of the dishwasher) now run a long thin wire through the drain hose line poke around and pull in and out!! it may take a few tries but its better then a large Bill!! replace hose and hit drain button!!
Please rate response and help keep this site free!
Jan 06, 2009 | Samsung HL-S5087W DLP TV
GE Triton XL Dishwasher
It's normal for a little water not to drain. However, many times it's that the drain hose isn't looped up high enough under the sink and water is draining back from the sink or disposer drain- into the dishwasher. If there's a disposer, be sure to run it once in a while, a good time is when the dishwasher drains. The hot water and detergent keep the unit clean, and draining correctly.
Oct 24, 2017 | GE Tritonr XL GSD6260JCC Dishwasher
Open Questions:
See all GE 24 in. GSD4320Z Built-in Dishwasher Questions
GE 24 in. GSD4320Z Built-in Dishwasher Logo
559 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
