Frigidaire Gallery Model GS26HSZBB2 ice maker doesn't fill up
Model GS26HSZBB2 ice maker doesn't fill up completely and is only making 3/4 of cube capacity. It also doesn't work continuously unless I raise and lower the arm.
Re: Frigidaire Gallery Model GS26HSZBB2 ice maker doesn't...
Hello.
It is time to replace your icemaker. The best place I have found to get them is at Lowes. They are above 100 dollars everywhere else but they are 49.99 at Lowes. The part number is IM115. Just let the guy in appliances know you need an icemaker for a Frigidaire unit.
Sounds like its not getting enough water to the ice maker tray during each cycle. Possible restricted water fill line, plugged water filter or low water pressure to the ice maker.
You might be well served with a general defrost of the unit. But before you do, make sure that the mounting screws on the ice maker are fully in. Then if so, warm the lower surface of the ice maker where cubes are ejected with a hair dryer for a minute or two (medium not high). It could be that extraneous ice is catching the cubes. What does it feel like to the hand?
Hollow ice cubes are a result of lack of water to ice maker. This can be caused by lack of water pressure (clogged filter, bad water valve, obstructed fill tube, etc..) you will need to find the cause to correct this hollow ice cube issue. The ice maker should take on 5.5 oz of water when it cycles (2/3 cup). Mot of the time its a water supply issue and the line could be kinked behind the unit as it was rolled back into place.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in. Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
As every technician knows , a water and ice dispensor refrig , has a dual water inlet valve . Just because the water dispensor works , does not mean the coil for the ice maker is working . Pour about 2/3 cup of water into the ice maker . If it dumps the frozen cubes , but does not refil with water , check the fill tube inside the freezer , from the wall to the fill cup on the ice maker , to see if it is frozen . If so , replace the dual water inlet valve , due to seeping . This is not closing completely , and letting drips thru , which freeze inside the tube . If the tube is not frozen , then the water inlet valve is bad , not letting water thru to the ice maker .
If the ice maker does not dump the frozen cubes , then the ice maker needs to be replaced . Also check the coils under the refrig , to be sure they are clean of dust , lint , etc , as this will raise the temp above 5 degrees , which is the operating temp , for an icemaker .
sounds a liitle to fast actually, its rated for 8 cubes for "harvest"(cycle, and each cycle problably about 1:45, ittl take a while to fill the bucket , perahps 36-48 hours. once filled though maintains good normal use levels.
Chances are it will be best to replace the ice maker but give me your complete model # from the sticker inside the fridge. Also, make sure the fill tube to the ice maker isn't frozen up. There should be a 3 digit # in front of the 52554100.
