Home Logo
Posted on Jan 18, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clock chimes on the 1/4, but hour chimes just once. When i use the lever on the side, it will chime the proper hour, but when the clock is running only the one time on the hour.
UsedClockPartsdotCom
Level 3:
  • Chime Master 277 Answers
  • Posted on Jan 29, 2017
Chime Master
Level 3:
Answers
277
Questions
0
Helped
146999
Points
4537
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Seth Thomas wall clock doesn't chime on the quarter, half or three quarter hour but does chime on the hour
Please change the time of your wall clock back 1 hour and check if the other 3 chimes return. There should be knobs on the side of the clock to help you do this. If not on the side, then please check on the back. Since you've already checked the settings and ruled them out as the cause of the issue (as well as the batteries), you might need to perform a factory reset on the clock if the steps I mentioned above fail.
Thank you.
Strausbourg manor quartz Westminster mantel clock. Why did it stop chiming?
Source: Wikipedia
The full hour chime is followed by one strike for the number of the hour by Big Ben (E3) (one strike for one o'clock, two strikes for two o'clock, and so on). ... The mechanism then plays two complete sets of five sequences for each complete hour.
Source: PortableFireplace
Learn how to fix a mantel clock that chimes at the wrong hour. This simple fix will repair a clock that chimes at the wrong time. This can commonly occur when your mantel clock is laid down on its back and the timing is offset.
1 Thing You Have to Understand First On most clocks you can turn the minute hand counter-clockwise but SOME clocks are not safe to be turned in that direction. For this reason, it's best to only turn your minute hand clockwise just to be safe.
The Simple Mantel Clock Adjustment The easiest way to adjust a mantel clock chime is to move the hour hand to the hour that the chime is striking. Make sure that the hour hand shaft is not too tight or else it will not turn. Most mantel clock hands are friction held. DO NOT BEND YOUR HOUR HAND, loosen the shaft if it will not turn freely.
Once you have synchronized the hour hand with the hourly chime, adjust the minute hand to set the clock to the correct time by moving it forward (clockwise) around the clock face. Allow the chime to strike at every quarter hour strike.
Mantel clock Chime Adjustment When your mantel clock chimes the wrong number of times, your chime is not synchronized time of the clock. To adjust your mantel clock chime, proceed with the following step:
ADJUSTING THE HOURLY CHIME
  1. When your mantel clock chimes, count the number of times it chimes. This is what time your hourly striker is set to.
  2. Move the hour hand to the hour indicated by the hourly chime (count the number of gongs at the hour).
  3. Reset the time using the minute hand to the correct hour and the chime should adjust along with the clock hands as well.
ADJUSTING THE QUARTER CHIME
On most mantel clocks, you can simple remove the minute hand which is friction fit. You have to apply pressure on the tube and it will loosen. Once removed, re-install the minute hand at the correct time. From there you can rotate the minute hand to reset the time.
Mar 17, 2021 • Home
2helpful
I need the full instructions for the setting of my sunbeam Westminster quartz clock - model# 882-495
A similar question was asked on FIXYA a number of years ago, and may prove useful:
http://www.fixya.com/support/t476305-instructions_sunbeam_clock_model_882
Instructions for Sunbeam clock model # 882-495
Sunbeam Westminster Clock, model # 882-495. Clock was just given to me with no instructions. battery has been replaced and I'm trying to figure out if the clock is broken and no longer works or if I don't know how to properly set the time.
Posted by Anonymous on Mar 29, 2008
OldPoop55
Move the second button from the left to set, enter the time in 24 hour format via the HH and MM buttons, then move the button to start. The far left switch, on/auto.off is for the chime. Set to on for 24 hour alarms, set to auto for no chime from 11pm til 6am, set to off, to turn it off.
Posted on Jun 08, 2011
  • dan daniels
    I had to leave the far black left switch on or up,turn the white set /run switch to set..the far left hour is the 10 , the next hour is the 1, the next min is the 10, the far right is min 1.
    when you want to set tghe clock time .press the button and count the chirp for the time..for 10: 36 press the far left button 1 time.. do not touch the next 1 hour button..: touch the 10 min button 3 time or 3 chirps.. press the 1 min button 6 times or chirps.. then set the set switch up or run..the chime should chime every 15 min.. and the hour should chime for te hour on the hour..
    Posted on Apr 23, 2013
    • tlwhitley1
      YES! Like BA said, inside the clock are switches. Turn one to OFF. Move the other to SET. Then push the H button the # of the hour it is. There are one (far left) and two digit #s (far right). I'd tried to fix this clock we bought for my mom and dad some 15 years ago.....finally the clock works again! Thanks BA!!
      Posted on May 13, 2010
      • Anonymous
        JUST PRESS THE BUTTONS ON THE INSIDE OF THE CLOCK WHILE THE MAIN SWITCH WAS IN THE OFF POSTION. ONCE THE HOUR AND MINUTE WERE ADJUSTED, THE MAIN SWITCH WAS SET TO ON AND THE CLOCK WAS TICKING.
        THANKS.
        Posted on Mar 30, 2008
        • Luke Green Feb 01, 2014
          the clock has a set button,turn the clock on and turn the set button to set,then where the hour buttons are there are two,one on the left and one on the right.When you completed the steps above,Press thesecond button on the right side of the hour set,then for each time you press it,the clock will adjust per hour.So press itonce and then press test,it should give u one chime,press two and it should chime for two oclock,press three times and it should chime three time,usew this theroy and it should be all you need,ofcorse you will have to use common sence.Thanks and good luck
          remember for each time you do this u have to move the button from set to run for complete test.SO set to set then press one on the second button of hour,then turn it from set to start and then try it again.make sence?each time u adjust it you have to turn it from set to on then try the test after each adjustment.Good luck
Oct 05, 2019 • Home
I have a Linden 7076 chime clock. On/off/auto, start/set, H 2 buttons, M 2 buttons, volume wheel, test button and a wheel to adjust hands. I have no manual. What do these do so I can operate it?
Step 1 Wind your clock once a week by inserting the winding key into each of the three keyholes on the front of the clock and winding until the key won't wind any more. Make sure to wind your Linden clock before attempting to set it.
Step 2 Access the clock hands on your Linden clock by opening the glass door on the front or back of your clock, depending on the model. Use the winding key, if necessary, to unlock the clock's front or back door.
Step 3 Set the time on your Linden clock by moving the clock hands to the appropriate time. The hands of your clock can be moved clockwise or counterclockwise.
Step 4 Locate the chime-selector lever that extends from the opening next to the "3" position on the clock dial.
Step 5 Move the chime-selector lever to "Whitt" for the Whittington chime, "St. Mich" for the St. Michael chime and "West" for the Westminster chime. Set the chime-selector lever to "Silent" if you don't want your Linden clock to chime at the top of every hour.
Aug 25, 2018 • Chime Home
After spot cleaning mantle clock with German movement (circa 1960), the clock chimes properly on the hour but does not chime on the half hour.
I am hoping that you oiled it also? One trick I have found is to gently lift the hammers and release, sometimes the hammers will release and strike the chimes/gong. Do this 4-5 times and hopefully it will get it chiming for you again.
UsedClockParts.com
Nov 09, 2016 • Home
2answers
How do I stop the continuous hour chimes on a WESTMINSTER chime mantel clock ?
Is this a older type mantel clock or an electric. A older one has a small arm on the back of the wooden case just move it to it's opposite position and that should stop all chimes. A few times that small switch is on the inside but very rear. If it's electric it also should have a switch to turn off all chimes.
Feb 06, 2015 • Home
1helpful
Need setting instructions for clock movement
Howard Miller offers this feature: This is how it works.
Automatic Night-Time Silencing Option
Grandfather Clocks will offer a night time shutoff option. There are 3 options on this lever.
1) "Night On" - This will keep the chime striking 24 hours
2) "Night Off" - This position will turn off the chiming between 10:15PM and 7:00AM
3) "Strike" - This position will allow the movement to strike the hour without the Westminster melody if the other Westminster melody lever is turned to Silent.
Hope this helps.
R/David
Elgin grandfather clock chimes not working
I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
24helpful
5answers
Top Chime Home Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
Are you a Chime Home Expert? Answer questions, earn points and help others
