I have an Everstar portable AC, the power light is on but no other light come on and the unit does not come on, except when I unplug it and plug it in it comes on for about one minute then goes off. No error codes no lights.
  • davisac1 Jul 22, 2009
    Hi, it is not the timer or the reservoir, those were some of the first things I checked.It only comes on some times when I Unplug it, and as I said only the power light is on not even the temp. setting light comes on.
  • 6,784 Answers
HI, your unit is equipped with a run time device(timer). It may be set to a short run time. Make sure the timer is not on.Secondly, Make sure the temperature in the room is not lower than the set temperature. This will cause a short run time as well. Wait until the room temperature rises to operate unit. This will ensure optimal performance.
The above suggestions are linked to the most common reasons for this type of issue that you are experiencing at this time but, if these suggestions do not yield results, this will confirm a more serious issue that concerns the main control sector. this will require the skilled hands of a qualified Everstar service tech.
Posted on Jul 22, 2009
  • 2 more comments
  • Michael Masters
    Michael Masters Jul 22, 2009
    ***(((Worst case scenario will be a malfunctioning compressor. there is a safety circuit breaker that will cut the compressor current feed and blower fan as well if the compressor is faulty. although highly uncommon, this may be the reason for the quick shut-down)))
  • Michael Masters
    One more thing to check before you service this unit is the reservoir. it may be full. this will shut off the unit if so. make sure it is emptied in this case. if the reservoir is not the issue, please disregard this statement.
  • Michael Masters
    I see, this will confirm a major control issue in this case. the main control board consist of several logic chips that control the compressor and fan. this control , also, controls the runtime as well. I recommend replacing this board asap. this will restore the proper runtime and, operational value of your unit.
  • Michael Masters
    The temp light is directly wired to the control board. this is a strong indicator of control board issue. the light receives the current needed for illumination form the control. if this light isn't illuminated, the control is defiantly damaged.
    A service call is needed.
Unit will not power up just displays E1 Any tips to get this working again.
Not sure what kind of unit you have. Try turning off the main power/unplug it. Wait 5-10 mins and then restore power. E1 is an error code but w/o more info I can't tell what it means. If you have the make/model #? Or the owners manual should tell you.
Jun 23, 2015 | Everstar Portable Air Conditioner Everstar
Everstar Air Conditioner Portable has power to unit but screen is blank, no fan or cool!!
make sure you have power to it, try using another plug if not it sound like a bad board, the boards and screens can be ordered and replaced
Oct 22, 2013 | Everstar Portable Air Conditioner Everstar
Portable ac blows warm air even after i cleaned filter
Make sure that the coils are all clean, Vacume cleaner with the brush attachment on the end works well.
Sounds like your fan is only working and not the Compresser that makes the unit an "air conditioner" and not a gloryfied fan.
Check and make sure that the butten is on Cold and that the small water drawer is in correctly so the shut off switch is making good contacts. Important Make sure that it is getting enough electricity at the wall plug, Because when the ac compresser 1st turns on it uses 3-5 times the power for the intial startup, not enough juice means no AC.
The fan only uses a little to blow but AC needs alot to start.
Unit should sound diffrent when AC compreser turns on compared to fan only on mode.
Sep 03, 2009 | Everstar Portable Heater/Fan
Everstar portable ac 10000 btu
The everstar 10,000 BTU unit will require a dedicated 115 V 15 amp circuit. if there are other things pluged into outlets and running from the same breaker then the 15 amp breaker will trip. Or, these units also have a GFCI plug adapter. Be sure it has not been tripped due to an improperly grounded outlet, or wet location.
Aug 22, 2009 | Heating & Cooling
Everstar MPA 08CR Portable AC unit. Water full
Your float switch is faulty, replace.
Jul 02, 2009 | Heating & Cooling
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
UNIT SHUTS DOWN AS SOON AS COMPRESSOR KICKS IN
Hi fdisc I feel quite sure your compressor is going straight to ground you need to get someone to check the comp, for its resistance and he or she will soon let you know for sure.
Regards
Steve.
May 24, 2009 | Danby DPAC8020 Air Conditioner
Everstar portable ac unit displaying error message P1. The unit turned itself off and will not come back on. It had no symptoms of not working well before turning off.
According to my Everstar manual, P-1 is a drainage problem.
EverStar owners manual pg. 16 -
1. Release the drain hose from the ruber clip and pull out the rubber plug, let the drain hose slant down to a water container.
2. Press the TURBO button on the unit control panel for more than 3 seconds and the WATER INDICATOR light begins flashing. It indicates the forced water drainage feature is activated.
3. Waiting until the WATER INDICATOR light stops flashing and there is no water flow.
4. After the water has drained, remember to secure the drain hose and plug in the upright position and clip it to the unit.
The unit will return to normal operation.
....I had to do this and it worked - Good luck!
Mar 25, 2009 | Heating & Cooling
PORTABLE AIR CONDITIONER (EVERSTAR BRAND)MODEL MPA08CR NEED HELP TO OPERATE THIS ITEM
IF ANYONE NEED TO SEE THE OWNERS MANUAL FOR THE
EVERSTAR PORTABLE AIR CONDITIONER MPM2 , MPM210CEBB6
MODELS # MPM2 - 10CE - BB6
MODELS # MPM2 - 10EE - BB6
MODELS # MPM2 - 10CR - BB6
MODELS # MPM2 - 12CE - BB4
MODELS # MPM2 - 12EE - BB4
MODELS # MPM2 - 12CR - BB4
YOU CAN E-MAIL ME AT - RICHCPZ@YAHOO.COM
I'LL SEND IT TO YOU IN A PDF FILE
(AS LONG AS I DON'T LOOSE IT IN MY COMPUTER )
Jun 21, 2008 | DeLonghi PAC85 Portable Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
