Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Freezer AND Fridge just QUIT!! Lights on, fan running. Wife went to get ice, nothing cold OR Frozen. This happened yesterday, I was out of town. Friends unpluged, took outside, Today, cleaned coils of dust and plugged back up. Waiting to see results. any hope or ideas?
    Problem Solver:
  • 7 Answers
If it is an auto defrost model check the defrost timer has not stuck.
Posted on Jul 22, 2009
FRIDGE TO WARM MODEL ED22DWXTNOO
It's a circulation problem so either the fan in the back of the freezer(circulates freezer and blows cold into fridge) or the defrost element. If the element is faulty the rear ices up and air won't flow. If fan is faulty it's not blowing the cold air. Remove rear panel if no ice it's the fan if its full of ice it needs the defrost element(usually get termination sensor also depending on type) If you open the freezer door and hold in the doorswitch you should hear the fan running if its working.
Jul 08, 2013 | Kenmore Ice Maker Kit For Sears Whirlpool...
Why freezer not working...ice is melting
Can you hear the fan running in the freezer when you have to freezer door open? If not the fan that blows the cold air over the cooling coils is either broken, or the fan is frozen in ice. We had this happen to us. We thought the fridge was dead. removed panel in the freezer compartment (in the back) and exposed the fan. Changed the fan, works good. good luck
Apr 19, 2013 | Refrigerators
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Freezer will not keep foods frozen fridge will not keeep temp.
Sounds like a main control board problem keeping the freezer fan from working . If no air flow to the top of the freezer , the icemaker will stop working and the ice will begin to melt ( leaking from freezer ) . The coils will start to freeze up due to no air flow across them . If continued for a period of time , the cold air could return thru the return vent located in the bottom of the ref/freezer section and freeze the water tank in the refrig section , causing the no water thru dispensor .
Jul 11, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
GE Side by side refrigerator not working
THE FREEZER FAN BLOWS COLD AIR TO THE FRIDGE SIDE, TO ACCESS THIS FAN YOU NEED TO EMPTY THE FREEZER SIDE AND REMOVE THE REAR PANEL SOMETIMES A WHIRL OF IT WILL GET IT SPINNING AGAIN BUT YOU MAY AS WELL CHANGE IT
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Bottom of freezeer and fridge are cold, but top areas aren't?
you have defrost problem or check see if condenser fan working
Apr 07, 2009 | GE Refrigerators
Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged drain.you need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot water.you will see when it is unclogged,water will run down drain without running over into bottom of freezer.
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Freezer not freezing
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Sep 28, 2008 | KitchenAid Superba Architect KSCS25INSS...
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
223 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
