SOURCE: Toshiba CF30E50 TV shuts off
You power supply coil is bad (transformer) prolonged run time causes to heat material as a result of expansion loss of contact no conductivity red light no power
SOURCE: IBM R32- battery light problem
usually when the charging light blinks and wont change to solid green it means the battery is dead.
solution is to buy a new battery
SOURCE: have power cord plugged into
lets try this ---
* turn of your computer
* remove the plug from your computer.
* Remove the battery from your computer
* Let it sit for 3-5 minutes
* Replace the battery
* Plug your computer back in (Make sure the wall outlet is working as well, seems simple, but have seen it before)
* Let it sit for about 3-5 minutes
* Boot your computer
* go to
Start -> Control Panel -> Power Options -> Power Meter
Note the Total Battery Power Remaining
* Let your computer sit for 15-30 Minutes and see if the Total Battery Power Remaining has gone up.
If so problem solved
if not you may be time for a new battery.
