Question about Kitchen Ranges
The oven will not display flames or heat up. - Kitchen Ranges
  • 1 more comment
  • acebowler1 Jul 22, 2009
    everything else works on the range including the oven light.
    ge spectra xl 44
    Yes! I suspected as much but did not know the checking it out method.
    Thank You.
  • 3,037 Answers
Can you please give me the make and model number of the oven in question and anything else that may help me solve this problem.
Benjamin
Posted on Jul 22, 2009
  • Benjamin Patri
    Benjamin Patri Jul 22, 2009
    Your going to have to open the door to find the pilot light. Next to
    the pilot light you will see a small rod with either a copper tube or a
    wire leading to the combination valve. This combination valve has the
    brown button that you have to push in order to light the pilot light.
    This rod is called the thermocouple, and this is what opens the pilot
    valve and the burner valve on the combination valve. When you hold down
    the brown button and light the pilot light, the thermocouple heats
    enough and opens the pilot valve, so that you can let go of the brown
    button. The thermocouple then gets hotter, opening the burner valve.
    Your going to have to check that the tip of the pilot light flame, is
    just touching the thermocouple in order to get it hot enough to open
    the two valves. The tip of the flame is the hottest part of the flame
    and you can move the thermocouple in order to adjust it. Also check
    that the pilot light is close enough to the burner. Sometimes things
    move out of adjustment, and it is extremely easy to fix.
    If the thermocouple gets red hot and still not keeping the valve open,
    then try to replace it. If it is the common copper tube type, you can
    go to any hardware store, in the hot water section, and buy one for
    about $20.00 If it is the wire type, the your going to have to order
    one. If this doesn't solve your problems, then you might
    need to replace your combination valve, and that might get expensive. Let me know how this turns out.
    Benjamin
    President:
  • 1,714 Answers
Do you have power at the plug? Try resetting the GFI reset buttons on all kitchen outlets.
Why t takes long time for oven to heat up?
Does the oven actually heat up with the temperature more than 100 or does it just stay at 100? Alternatively, when you open the oven can you see the orange glow of the flame through the vents in the bottom of the oven and hear the gas hissing?
Aug 18, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
Hot surface igniter will glow and put out a flame but is not a blue/orange flame
First you need to get a nice blue steady flame to prove to the ignition module there is flame. Check you orifice and bypass tube.
Feb 22, 2014 | Lincoln Impinger 1116 Gas Oven
Very small flame takes like ten minetes for flame to get high
The reason the flame in the oven is so small and takes for ever to heat up is because the oven igniter is weak and can not open the gas valve very much so hardly any gas flows resulting in a low flame size. By replacing the oven igniter the flame will be full size and heat quickly.
GENE
Oct 16, 2011 | Sears 61301 Gas Kitchen Range
It won't heat up... even though there is a flame
Check The Power Source
If the gas oven won't turn on, the first thing to do is check the power source. Most modern gas ovens are electrically powered. Check to make sure the oven is plugged in and the breaker isn't tripped.
Check the Heat Source
When a gas oven won't heat, the pilot light can also be set too low; if the pilot is lit but the oven isn't catching, adjust the flame.
Newer gas ovens use electric ignitors that produce sparks. If the oven doesn't heat, the ignitor could be broken.
Feb 05, 2010 | Ovens
I saw sparks? or small flame on back wall behind fan inside oven
It sounds likely that the fan motor is faulty,more so if the oven is heating to some extent.
You should be able to see or hear if the fan is working or not
Hope this helps with your prob.
Nov 26, 2009 | Gaggenau EB 270/271 Electric Single Oven
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
Low flame and not heating oven
we had the same problem on our 10 yr old creda. gas man said new ffd required (flame failure device). he reckoned on around 80 pounds sterling for new part,even if it was still available, plus maybe 2 hours labour. we bought a new cooker!
Nov 24, 2008 | Stoves 1000DFDLm Gas Kitchen Range
High flames in oven
Flame saftey device control valve stuck in open position that why main gas is coming other wise flame should be max 2cm long after flame saftey device heat up and bellow expand and main valve should open
Jul 21, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven heat
The problem with you oven is the FFD (flame faliure device ) also known as FSD (flame safety device) The way is works is that when an oven is ignited first time the heat from the low level flame heats phail at the end of the calliary tube which in turn increases the pressure within this tube forcing open the FSD valve to open allowing full gas through. when this fails it restricts the amount of gas flowing through it leaving the oven with a small flame. these are easily repalaced but the law says it must be done by a corgi registered engineer for gas safetey reasons...But 110 % that is your fault. HTH
Dec 04, 2007 | Frigidaire FGF316 Gas Kitchen Range
Gas oven not heating
waka,
I'm guessing that there is an issue of some kind with flow of heat inside the oven. Gas ovens use the hot air/gas exhaust to heat up the oven. Flames mean heat. The flames should be about half an inch long or so. If not, there may be an issue, but I don't think that is it.
Have you lined the oven with foil? It is possible that vents from the boiler section are closed up? That will prevent heat from reaching the oven.
Dec 03, 2007 | Whirlpool SF367 Gas Kitchen Range
Kitchen Ranges Logo
27 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
