SOURCE: Heater only blows hot air if I rev up the engine to about 4000RPM
make sure it has a thermostat
SOURCE: Krups model KM7005 water wont heat
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at [email protected].
SOURCE: hot tub pump flo-master hp suddenly wont start.
The fault is most likely to be the condensor. They can and do fail at an early age.
You don't need to dismantle the pump, on the rear of the pump you'll find a slot on the motor shaft which can be turned with a screwdriver.
If you've only just reffiled the hot tub it could also be an airlock.
Regards,
Ian.
http://hottub.synthasite.com
SOURCE: ENGINE IDLES ROUGH IVE CHANGED PLUGS WIRES COIL
You might want to look at that injector for that cylinder.I worked on a GMC Jimmy that did the same thing and I also changed all the sensors come to find out that my injectors and the spider assembly needed to be changed.
SOURCE: J-300 won't heat. FLO readout
FLO = It typically for a Flow Switch or pressure switch (heater is
deactivated. Pump may also be deactivated).
It is most likely a flow/pressure switch failure.
Before you buy a replacement try running the spa with out the filter cartridge - Checking if dirty cartridge is the issue. Also check that all gate valves are all the way open & locked.
