Question about Cameras
Samsung bl103 will turn on and beep 3 times then pauses and beeps 3 times again and the lens is stuck in the out position
Mine does the same thing. I open the battery door and close it back up. Then I push the power button and the lens will retract. When I turn it on afterwards it works fine. Mine does this quite often.
Posted on Jul 22, 2009
My Samsung BL103 was dropped by my daughter and now the camera won't turn on and the lens is stuck in the out position.
There is Lens adjustment out you need to fix this problem by opening your set and Lens block to readjust.after that it will work.care fully handel this.
Oct 30, 2010 | Samsung BL103 Digital Camera
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
Beeps three times but does not come on, changed batteries, zoom stuck... not going back in
I found this answer on another forum. I giggled the lens as it was stuck out and then pushed the power button to guide it back closed. Then I gave it a soft whack on my palm when the lens was closed. I think I had a piece of sand stuck where the lens goes in and out. I also made sure that the battery type was Ni-Mh instead of alkaline on the menu. This is a recurring problem with Samsung cameras.
Jul 22, 2010 | Samsung BL103 Digital Camera
Lens stuc and makes beep sound
I had the same problem and my brother just wiggled the lens shut carefully while turning the power on at the same time , it took about 5 tries and finally had the lens was all the way back in place and it works great.It was just the lens was stuck open and would not start up like that I guess. better then junkin it.
Sep 01, 2009 | Samsung BL103 Digital Camera
Lens is stuck and it wont turn on
Same thing is happening to my camera. If you bought it with in a year call samsung, their customer service and warranty service is great. If you are not sure when you bought it, they can check with the serial number I believe, but most of these cameras were available around black friday last year. Have the camera with you, go through the process the representative tells you to do and as whit my camera they'll determine they can't troubleshoot over the phone and send you what ammounts to an Return Authorization # (RA#). The whole call will probably take about 10 minutes at most.
Gool Luck
Jul 22, 2009 | Samsung BL103 Digital Camera
Samsung bl103
Mine did the same thing. Just let it sit for a couple of days. Don't mess with it. It'll eventually stop doing that and work. That's what i did. It worked for mine.
Jul 15, 2009 | Samsung Digimax D53 Digital Camera
Lens stuck half way outm weird beep sound can I fix it
I get the three beeps also but the lense is fully retracted. I'm no expert but I've had this camera fixed once (would not focus) and is going back in for this latest issue. I like the little thing but I wish it would not break as much as it has. On the other hand I've had great esxperiences with smasung's warranty service. If your camera was purchased less than a year ago it is still under warranty and a quick call to samsung will get you a shipping lable to an authorized repair center free of charge. You only pay for shipping to the repair center.
Good luck
Jul 14, 2009 | Samsung BL103 Digital Camera
Lens stuck in out position, beeps 3 times then off.
Just had same problem with mine, I wiggled/turned the lens a couple of times before turning it on, and it popped out of the stuck position and closed again. It's working - but clicking when I move the lens in or out.... :(
Jun 09, 2009 | Samsung Digimax S700 Digital Camera
Camera Stuck with lens out. Beeps
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
Jun 03, 2009 | Samsung Digimax S630 Digital Camera
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
Cameras Logo
410 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
