Question about Hayward 1.5hp Max Flo Inground Pool Pump # Sp2810x15
I GET 230 VOLTS AT INPUT TO MOTOR BUT PUMP DOES NOT START OR RUN?
  • 520 Answers
If you have verified 2 separate legs of 110+v at the pump you will need to check the start and run capacitors..these give the motor a voltage boost to "jump start" your motor. The run capacitor is mounted under the large extra dome (cover) along the motor housing which can be removed by two screws.Remove this cover (power off!) and you will find a metal cylinder with 2 wires connected.This is the run capacitor and you will find it is probably rated 370v x 25-50 mF. If you have no means of checking this capacitor with a DVOM(meter) or capacitor checker device which measures microFareds then Replace this unit($10).This pump may or may not have a start capacitor ...if it does,it will be behind the rear cover(2 screws) and it will look alot like the run cap but a bit smaller and plastic.If you discover your motor to be split capacitance motor it will have both these capacitors in the described locations. Be sure to match the ratings of replacement capacitors before installing. good luck
Posted on Jul 22, 2009
Looking for a new motor for a utilitech pro 0313836 submersible pump
Most submersible pump motors are interchangeable.
A 230 V motor will run cheaper. Be sure to get the correct HP motor.
Oct 05, 2014 | Utilitech 1-1/2-HP 18-GPM 3-Wire 230-Volt...
Wiring a 230/115 1 hp 56y pool pump motor
please verify the name plate to be 115 230 volt motor.there will be a schematic that shows you exactly how to hook up this motor depending on the voltage being supplied to it. The main thing is switching between 115 and 230 volts this is a selector switch this very easily forgotten about. Please make sure to check that and double check that to make sure its on the proper selected switch. Good luck
A thumbs up would be greatly appreciated if this answer is helpful to your free Fixya question
Jun 30, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
I just installed Hayward 1.5HP inground and it tells me that if i use the 115v to use a 30 amp breaker - and when i left the 230V button positioning inside the back of the pump and connected with a 14 ...
double the amps, 230 runs cooler (my fav) . 1.5 is 9.6 amps at 230 volt. you will need to set the motor to run on on the lower voltage this is why you are having problems.. also the motor is thermally protected . this why it will run for awhile and shot off .. remember to prime the pump after any pump repair !!!! . jay the pool pump repair guy in longwood florida
Jun 05, 2011 | Hayward 1.5hp Pool Pump Motor Motor A O...
Just replaced motor overheating and shutting off.
service factor must match old motor ! motor must match impeller hp rating ! .. get the numbers off the impeller and search it on the web.. bet your motor is too small.. the easy fix ? buy the right impeller for your motor.. the things you need when buying a impeller are as fallows.. your motors hp and SF .. thats the service factor ! if the voltage is 120 v the motor set on 240 it will jump back and forth between start and run.. it will make a click ..click ..click noise .USE A VOLT METER. I smell a northstar a real pain of a pump.. REMEMBER TO BUY AMERICAN PRODUCTS (PLEASE) AND SUPPORT YOUR LOCAL POOL PUMP REPAIR GUY.. AND GIVE ME A THUMB OR TWO ,IF;N YA FEEL I WAS OF HELP ..JAY FLORIDA
Sep 10, 2010 | AO Smith 1.5 hp 3450rpm 56J Frame 115/230...
I purchased a new 3/4hp Emerson pool pump installed it and the only thing it will do is hum.
OUT THE BACK SIDE OF THE MOTOR IS A SLOT IN THE SHAFT FOR A SCREWDRIVER , SEE IF YOU CAN TURN THE MOTOR OVER(BREAKER OFF !) YOU MAY HAVE BOUND THE IMPELLER OR IT COULD BE SET FOR 230 VOLTS AND YOU ARE RUNNING IT ON 115VOLT.....
IT MAY HAVE A BAD START CAP OR THE SWITCH MIGHT NEED CLEANING. THESE EMERSON MOTORS CAN BE HARD TO WORK ON DO TO THE HUGE AMOUNT OF PLASTIC PARTS
Jun 20, 2010 | Hayward 3/4hp Super Pump Inground Pool...
I'd like to know how to change a 115/230 volt pool pump motor to run on 115 volts after I've already change to internal possition to 115 volts
IF YOU SEE ON THE LABEL ON THE MOTOR HOW TO CHANGE FROM HI - LO VOLTS . THATS ALL YA GOT TO DO ..THE WIRES HOOK UP NORMALY
May 21, 2010 | Hayward 3/4hp Super Pump Inground Pool...
How to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
Aug 28, 2009 | Dayton Permanent Split Capacitor Motor Fan
1.5 hp waterway champion pool pump issue
Be sure you have connected the motor to the line leads correctly and that the motor is set for the proper line voltage.
A somewhat common problem is that most motors are dual voltage (can be ran on 115 or 230 volt) and come factory set for 230 volts. If you connect it to a 115 volt circuit it will run for a while and then overheat and shut off.
Jul 28, 2009 | Waterway Champion 1 1/2 Hp 230v Energy...
Pool pump burned out - Wayne WIP150
You can go and buy a new motor, but that is about it...short of having the motor rewound, but I think you would find this to be a more costly option.
Jul 08, 2009 | Plumbing
Clicking noise in new Hayward Super Pump
It sounds like the wear ring on the impeller is hitting the diffuser. If it is new call Hayward to fix it under warrenty
Best of luck
Jun 04, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Hayward 1.5hp Max Flo Inground Pool Pump # Sp2810x15 Logo
88 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
