Question about Hitachi 53SWX10B 53" Rear Projection Television
Sound , picture problem
....after set warms up the sound will drop down, the pix gets dark , picture flops over horizontally, color drops out....not a convergence problem....thanks for any help on this,,, jim
Re: sound , picture problem
Posted on Dec 24, 2007
  • 934 Answers
I think you may have a couple of problems cooking there. First, the audio board in that unit is commonly a lemon. Several Ic's on that board need to be checked, possibly replaced and there are even several modifications to do if something NLA is not working.. Your best bet is sending it into PTS for rebuild.
The second problem horz tear and dark pic could be a result of the spark gap, crt pins and/or crt board. A few simple tests for a shop can confirm that...
My advice is take this in... With the multiple of problems it would be quite difficult to determine what looks bad and what actually is on the audio board without a highly trained eye and technical experience. The other should be a breeze for a shop.
Posted on Nov 20, 2007
0 characters
3 Points
4 inch dark grey/blackish horizontal bar top quarter of screen.
If it had a fixed image of some sort that might also explain it---if you reopen a new question post the brand and model number.
May 31, 2012 | Projection Televisions
Dual picture, dark picture
Do you see the video like a 3D image?
Apr 29, 2008 | Sony KP-ER43M61 43" Rear Projection...
Our Mitsubishi wd-65833 tv turns on and makes a whistling sound like it is powering up-then the red lamp light comes on and it makes the whistling sound in reverse (kind of like the sound of a bomb...
This mechanical whining sound is typical of what is know as a color wheel fault. Color wheels are mechanical color disk that spins. generally if they do not reach a certain speed the set will shut down. It is a moving part and anthing that moves will eventally not move. other possiblilites might be cooling fans if they shut down then the lamp will shut down. to determine which a technician will need to remove the back and isolate where the sound is coming from.
Apr 21, 2011 | Projection Televisions
One horizontal line center on the screen
The vertical deflection circuit has failed, or has been shut down by a service code entered from the remote control*. Usually you can get out of service mode by turning the set off and on again.
*Normally, you have to enter a special combination of front panel and remote control codes to get into service mode, then enter another code on the remote control to get the horizontal line. The horizontal line is used for adjusting the screen controls for each color so you get proper color in the dark areas of the picture.
Oct 27, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
When i turn on tv, i get a picture for a second or two, then it fades to all blue screen, which lasts a second or two, then it fades to black. also, the stand-by red light flashes.
look for bad solder it sound like you g2 is drop off
if you open the set and have some stand in front of it you tap the board to see if pix come back if it do them you have bad solder you can see the g2 on your pix tube
the g2 will not be lit up at this a g2 pro.
Dec 07, 2009 | Sony KP-57WV600 57" Rear Projection...
Picture is very dark and color not too good.
Take the front speaker grille off; it is stiff but will pull off. Take off the access panel underneath; four or five screws. Inside you will find a screen/focus block control assembly. Get a flashlight. Turn up the screen controls SLIGHTLY. for RED, GREEN AND BLUE. The best way to do this is to turn off the color first and make sure you end up with a good black and white pix ( not tinged green, red or blue) then turn the color back up in the menu.
May 11, 2009 | Projection Televisions
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Hitachi 53SWX10B 53" Rear Projection Television Logo
98 people viewed this question
Top Hitachi Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Projection Television Expert? Answer questions, earn points and help others
