My Magnavox TV won't show me the A/V signal from my DVD player. I have gone through the menu and there does not seem to be an "input" function at all. I don't have the original TV remote. So the previous solution does me no good--unless I take it in for servicing. My RCA cables are good. Any other ideas?
  • 616 Answers
You can purchase a modulator which will convert the signal from you dvd to ch. 3 or 4. good luck Julio milleniumtvsvc@gmail.com
Posted on Jul 22, 2009
I have a rca truflat i can't get the dvd to play
are you sure you have plugs and source input the same.the tv has several diff.inputs look on back what inputs you are using then go in menu move input to the same
Dec 24, 2011 | RCA TruFlat 27F520T 27" TV
Cant hook up magnavox dvd player to t.v.
i hope the dvd player has the RCA cables for connecting the input signals to the tv for display and sound. the cables have input jacks at its ends and the same are color coded for easy identification on where to plug it in. with the use of colour insert the yellow pin to the tv yellow input and the same to the dvd and do the same to the white and red terminal and proceed on by turning the channel to AV and play
Sep 27, 2011 | Philips Magnavox DVD/VCR Dual Player
I have a Magnavox ZV427MG9 A VHS & DVD Recorder
U must make sure ur tv channels must work throught ur DVD and VCR unit.Then u can record it out the tv show programs.U must connect the tv air signal or cable to the DVD VCR unit in the antena port.Use another cable connect out on the DVD &VCR unit and in the tv signal input in ur tv antena input.Make sure u in the channel 3 or 4 switch desire back of the DVD&VCR of the back,and the tv correct to ur desire channel switch to 3 or 4 .U
can record tv shows now.
Aug 18, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
My Magnavox TV #19PSC5 0121 won't show me the A/V signal from my DVD. I don't have the original remote and there is nothing on the front panel or on the Menu that will allow me to get to the ''Input'' so I...
1.Check the input setting of your TV.Try to find the input setting of your TV go to menu and select the selected input you are using, its either rca input 1,2,3 or vga input.Try to read the label of your input if its input 1,2 or 3 then select the setting in input set-up.
2.Configuring the appropriate setting and still the problem did not solve.Try to substitute your DVD with another functional DVD.But before also replace your RCA cord to take away the probability of defective cord.After replacing another DVD and the problem is solve, your DVD setting must be check if its in pal or NTSC setting.Try to press N/P button on your remote.
3.If the following procedure does not work.Your unit needs to be check by an expert.This could be a service mode repair or internal components repair.
Jul 19, 2009 | Televison & Video
Remote doesn't work rca model #F32648,i can't access the input function. The onscreen menu doesn't show it or I cannot find it. Problem is without it I can not use the DVD player.
This isn't a solution but I am unable to acccess the input either. My tv is hooked to a dvd,vcr and direct tv satellite with a dvr. I watched a movie on the dvd and the tv won;t allow me to switch the input back to satellite tv.
Apr 10, 2009 | RCA F32648 32" TV
Completely lost the picture and sound. All that
You didn't mention from where your signal originates and that clue screen is common to many sets and means it is seeing no input signal.
The set would seem to be functional, otherwise you wouldn't be seeing the input selection menu.
While it is possible that the RF section/tuner (that handles the signal coming in) has failed, these are pretty solid.
If you have another set or can borrow one to connect to whatever source you have (antenna, cable, satellite) to see if a signal is, in fact, there.  As an alternative, you could connect your own signal source; VCR, DVD player, or, as it offers, HDMI or a PC and set it to whichever input you have supplied with signal.
Mar 30, 2009 | Toshiba 23HLV86 23 in. LCD TV/DVD Combo
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
I pluged this in & it wil not show up on my tv
You cannot use RF (channel 3 or 4) to see the output of the Magnavox. You need a RF modulator or separate video/S-video and audio inputs. The antenna signal is passed through the 2160 for analog signals.(and digital if you have a converter box or digital tuner)
tom
Jan 21, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
