Question about Sign Led Emergency Exit - Green
I had a LED red exit sign installed. The company rep told me it will light up after 24 hours. However it is not showing any light after 24 hours
    Sergeant:
  • 384 Answers
Turn the room light OFF and the EXIT sign will light.
Posted on Jul 22, 2009
What does red wire connect to?
When most emergency lightning is installed there are usually more than one being installed. Without knowing about any of the other wiring and assuming that you connected the black (hot) wire and the white (neutral) wire the red wire is probably used to link that light to other emergency lighting.
Jul 23, 2014 | Sign Led Emergency Exit - Red
We need battery (only) operated exit lights. Do you know if such a thing exists? We are required to install lit exit signs in a storage building we own, but the building does not have electrical power.
Yes. They do have lighted exit signs that require no electricity. Here is a website I found that has some.
http://www.theexitstore.com/self-powered-exit-signs.html
Nov 13, 2010 | Universal Battery Exit Sign Red Led ...
I have an LED exit sign that is not working. What steps do I need to do to troubleshoot?
If you've just installed it and it doesn't work, make sure that the ballast is rated for the power you're giving it. If you put 277v to the 120v taps, you've cooked it and the unit will have to be replaced. If you put 120v to the 277v taps, it will probably still work if you take it apart and wire it the correct way.
Otherwise, check all connections within the unit (even the ones you didn't make).
Jun 28, 2010 | Sign Led Emergency Exit - Red
Put new batteries in exit signs but the status light wont stay on green...it will switch back to a constant red meaning charging. What would be bringing the power of a new battery down all the time?
is the unit battery only or battery backup? if battery backup, the system is draining the batteries as it has no source of power.. if battery only there may be a connection problem or a faulty unit.
May 13, 2010 | Universal Battery Exit Sign Red Led ...
Side lights do not come on when you press the red switch
If this is a new installation, it may be that the battery just needs to be charged. Leave the power on for a while, then re-test.
If it is an existing exit light check the bulbs. If the bulbs are OK, the next suspect is the battery. Batteries Plus stores usually carry replacement batteries for various exit lights.
The only other culpret is the circuit board.
Usually the same make and model exit light are installed in the same building. Try swapping the suspect parts with known to be good bulbs and batteries from another fixture if you have one.
Feb 09, 2010 | Universal Battery Exit Sign Red Led ...
Projector's lamp won't light up.
Change thermostat and service it.Then solve your problem.
Dec 12, 2009 | BenQ PB8220 Multimedia Projector
Test on rear EXIT sign in rear exit of boiler room.
The red LED backup should come on when the regular light goes out. Maybe the battery has not charged up yet, or is defective.
Oct 11, 2009 | Universal Battery Exit Sign Red Led ...
S-750DD
Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
Oct 11, 2007 | Transport Schwinn Rechargeable Portable ...
Sign Led Emergency Exit  - Green Logo
249 people viewed this question
Top Sign Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Sign Electrical Supply Expert? Answer questions, earn points and help others
