Question about Asrock M810LMR Motherboard
Motherboard pc chips m810 lmr v7,1
Motherboard not booting to bios but getting power, getting two beeps from mobo but mobo battery sitting at 3 volts is this enough, and where to find beep codes for mobo if not in manual, or is the beep codes universal for motherboards.
  • 2008clive Nov 28, 2008
    My PC shows power led, on boot shows hard disk light for 20 secs only, nothing else happens/screen is totally blank. Hard disk does not spin. I've changed the motherboard for another M810, changed the RAM and checked the PSU voltages, which all appear to be within 0.3 of expected. How can I check CPU please - does anyone have any other ideas, the only common items now are CPU, PSU (and case!). Please help!
  • 205 Answers
The beep codes are not universal, but there are a few popular BIOS's and you can figure out what 2 beeps means if you can find your BIOS listed here:
http://www.computerhope.com/beep.htm
The name of your BIOS should appear on the monitor as you're booting.
Posted on Nov 20, 2007
What is that most critical part of the mother board..what is the most important part of it, that if become damage will totally stops its functions?
The main processor ic, located under the cooling fan, It is the heart of the motherboard, directs all functions in the system.
May 26, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Tip
Reflash Via EPIA-M 1000g BIOS when board is dead
I'm writing this in the hope that others like me can resolv their problem with the dead EPIA-M mainboard.The symptoms where.. on power-up .. it would make 2 high pich beeps followed by 2 low pich beeps..turned out that is the error code for dead BIOS.
OK so u have a dead bios and a mobo that won't boot for various reasons.. from flashing a wrong or corrupted bios or else.
Apart from the other ways to go around the problem like buying a new chip already flashed or flash the chip with a dedicated flasher u can follow on this simple guide.
You should at least have some experience in DIY in computers .
1. Find a mobo of an old  pc that uses the same socket for the bios chip.if it uses award bios even better.I used a biostar p4m800-m7a mobo to do this.
No need for it to have a hdd or something special attached to it.. power source and cd or dvd/rom will do.
2. Try to see if it boots, if all ok..
3. Get you hands on the Hiren's boot cd..burn it and boot from cd..it has in the Dos program list... in the next page BIOS/CMOS UTILITIES. Select uniflash 1.4.. i did it with the 1.4 on the hiren's boot cd 10.1 maybe if they update it it will work also.It will tell you the name of the bios chip and some details..make a backup of original chip just in case.
4.On other pc download the 109.BIN file .. the bios file known to be stable for the EPIA-M board. You can find it on some forum.. i can't remember now..I thank them by the way.Same the file on a fat32 usb key.
5.On the surogate board with uniflash started.. comes the tricky part: u have to get hold of some good tools and pull the bios chip out while it's running... don't worry, nothing will happen.
6. Pull out the dead bios chip of EPIA-M and put it in the surogate board.These steps must be done with absolute care.If you think you can't do it, wait or call a friend with more experience or get hold of the right tools
7. Now with the dead bios chip in place.. select in uniflash, rediscover bios chip.. or something like that,..can't remember well.. but you get it when you see the screen... the sst bios of the EPIA-M NOW SHOWS UP...
8. select flash bios and select the file on the root of the usb key by typing C:\109.bin.. if no hdd attached.. the key is seen as C, otherwise use letter accordingly.It flashes the bios in less that 10 seconds.. and says ok.. power off surogate mobo.. replace bios chip with original.. and enjoy now your EPIA-M mainboard again.
If you'd like to thank me or ask details..mail me at www_offspring@yahoo.com
on Jan 19, 2012 | VIA Epia M10000 Motherboard
I have a Soya SY-7VCA mobo that hasn't been used for about 6 years. Upon bootup, I received a CMOS checksum error message, but was still able to load a copy of Windows 98SE that I had on floppy. After...
Probably your BIOS battery, replace that and setup you BIOS again and it should be fine. BIOS batteries look like little round watch batteries.
Any more questions just let me know.
Thanks
John
Feb 14, 2011 | Soyo SY-7VCA Motherboard
Loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
Jun 10, 2010 | Dell Inspiron Mini 10 Notebook
PC power down after 3 seconds power on. Power
pull out the cpu chip and see if it comes on or beeps,
If it dont its the mobo.
Sometimes the mobo and the cpu go bad at the same time, a bad cpu can kill the mobo
Apr 15, 2010 | eMachines ET1641-02w (PT.NA60X.001) PC...
Power supply runs, but no bios or boot
yes it sounds as the the cmos bios chip is damaged, if theres no bios showing, you will have to replace the mobo.
Sep 03, 2008 | Dell XPS 200 PC Desktop
Fans runs but no post,no beeps.
The best advice I can give you is to remove the motherboard battery (UNPLUG THE PSU BEFORE YOU WORK ON THE MOTHERBOARD) and let the system sit for about an hour. If the CMOS settings are corrupted, removing the battery will erase the corrupted data in the CMOS, which will automatically reset the CMOS to the default settings... Then, plug the battery back into the motherboard, and try to boot the system...
If that doesn't work, you should disconnect EVERYTHING attached to the PSU, and remove ALL of the add-in cards (modem, NIC, soundcard, TV tuner, whatever you have), and install ONLY the CPU, the heatsink/fan (don't forget to PLUG THE CPU FAN IN), ONE stick of RAM... you get the idea. DISCONNECT the HDD, the FDD, the optical drive, and ANYTHING ELSE from the PSU. When you're ready to test the system, you should have ONLY the CPU, the HSF, and one DIMM plugged into the motherboard. Attach the PSU connectors (both the main ATX connector AND the auxiliary 4-pin 12-volt connector) to the motherboard, and try to boot the system. If it works, SHUT DOWN and UNPLUG THE PSU; then install ONE component (the floppy drive, for example), reattach the PSU, and reboot the system. If the system POSTs, shut down, unplug, and add another device. If the system does NOT complete the POST process, the last piece of hardware you installed is probably the culprit.
Take your time with this; be methodical, and make GOOD notes about the steps you've followed, so we can help you work through this problem...
Best of luck to you; keep us "posted" on your progress...
Jan 27, 2008 | ASUS P4P800 SE (890552603657) Motherboard
PC won't boot
Is the case speaker connected to the motherboard?
If it is, do you get any beep sequence? If there is no display, the power speaker output an audible beeps sequence. For example, 3 short beeps mean a problem with memory.
Keep posting here to zoom in on the solution.
Dec 28, 2007 | PC Chips A21G Motherboard
BIOS UPLOAD
Ah, that is a nasty problem. Sounds like the BIOS got corrupted. You have several options:
1. Get another bios chip from the mobo manufacturer.
2. Get another motherboard and use it to program your bad chip. See here how
3. Dump the old mobo and buy a new one.
I would go with option 3. The other options are just a big headache.
Dec 28, 2007 | EPoX EP-8HMMI-A Motherboard
Mb power issues
I would say a compatability problem with your mobo and the memory as no beeps, no boot points that way. Can you get in the bios to check all is showing that should be and dissable 'Halt On All Errors' in standard bios settings.
Nov 03, 2006 | Chips (M825G9.2/CNR) Motherboard
Asrock M810LMR Motherboard Logo
723 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
