Question about Karcher Garden
No pressure on a Husky 2600
I'm having the same pressure issue.
I checked the oil as you suggest here and am still with no pressure. What's next? thanks.
  • 174 Answers
Look for the Bypass valve and lubricate it
Posted on Jul 25, 2009
Can I USE SAE 30 NON DETERGENT OIL IN MY HUSKY 2600 PSI PREASURE WASHER.
Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
Pressure Washers Buyer Guide
Aug 03, 2015 | Psi Garden
What kind of oil to ues on pump ona husky 2600 preassore washer
I use the SAE30 Non-detergent Mineral Pump oil as it is formulated for the high pressure pump.
Feb 28, 2015 | Homelite 308653009 Blackmax Husky Pressure...
What kind of oil does a husky 3000psi pressure washer use?
I don't believe that Husky (Home Depot) makes any 3000psi pressure washer that operates with a 2 Cycle motor. So.... gas only in the gas tank. Husky pumps can be from several differant manufacturers... some use no oil, some are sealed and don't recommend any attempt at oil changes, and some use Non-detergent 30w oil and some use 20-50 Full Synthetic oil. You can look up your specific model specifcations with a google search for Husky pressure washer.
Oct 21, 2012 | Garden
Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
JUNK Home Depot
Nov 23, 2011 | Garden
My Husky pressure washer 2600 psi powered by a gcv 160 Honda. Engine starts no pressure other then from water source and soap is not being dispensed
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Jul 10, 2010 | Garden
I have a gas powered husky 2600 psi, hook up everything 3/4 hose line about 10 ft long, let water flow through w/o nozzle added, fire up the engine and when I pull the handle, engine stalls out . Any help...
Choke off?
Fuel quality, meaning no water, is essential of course.
If its brand new and this is the first starting, I would call Husky. Check oil..
The engine has a governor on it, so it should be sounding like its trying to not die...
Oct 20, 2009 | Garden
Absolutely no water pressure on my husky 2600 psi, I use sparingly..........
Hello there:
if you have already cleaned the filter for the hose than the regulating valve also has a filter assy with it too may want to check it also the nozzel will clog easily when sitting for a while. so you may want to check that out. ok
best regards michael
Aug 29, 2009 | Honda Garden
I hAVE A 2600 PSI HUSKY PRESSURE WASHER, AND I HAVE NO PRESSURE GOING TO THE NOZZEL. i HAVE CHECKED EVERYTHING AND EVERYTHING IS ATTACHED.
remove the pressure hose and turn your water supply on and water should flow thru the pump on out where the pressure hose is. If not you have a blockage in the pump.
Jun 07, 2009 | Garden
Absolutely no water pressure on Husky 2600 psi w/ HOnda motor
hook up water hose dose not pump water?
May 26, 2009 | Garden
Garden Logo
261 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
