Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas
Pool heater will not stay lit
Just moved in the house and got pool up and running. Heater would not turn on. Few days ago it turned on and now it won't. If turned on befor filter the it comes on with the filter and then cut off.
Check your ignition status. if you have a pilot ,make sure its lit. if you have a glo ignitor, make sure its glowing when you turn on the heater. sometimes it will glow but it might be hot enough to open the gas valve. also be sure to check your gas supply and make sure you are getting fuel to the unit.your heater will not turn on if your pool filter mode is enabled.
Posted on Jul 23, 2009
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
How to light teledyne laars 1 series pool/spa heater
turn on gas turn to pilot then hold down button light underneath where the small silver tube goes from the gas valve hold down lite then hold for a minute then turn to on should stay lit if not need new pilot generator
Jan 28, 2012 | Teledyne Laars Pool & Spa
I have a h150 pool heater. when you light the pilot it would go on but it would turn off once the valve was in the on position. service tech came to the house and changed the thermocouple. it finally...
Having multiple issues with a milli-volt heater very common and can be expensive to fix at times. Start by cleaning EVERY connection in the safety circuit and the pilot circuit. If you have a milli-volt meter that would help a lot.
Jul 13, 2017 | Hayward H Series Millivolt 250,000 Btu...
Hi. I just bought a house with a pool and Raypak RP2100 heater. The pool company came out and opened the pool and started the heater. It ran for a few days and has quit running completely. the pilot light...
Thank you for posting your question here on Fixya.com.
What type of filter do you have: Sand, Earth (DE) or a cartridge? The most likely reason it worked and has since quit is your filter has become dirty enough inside that the flow thru the pump and heater are reduced too low...there is a switch in the heater that senses this and turns the heater off to avoid boiling the water. Cleaning or backwashing the filter should fix the problem. If you have a sand filter or a cartridge filter look at the valve and see if there is a recirculate setting. If so, turn off the pump and change the valve to this setting. Turn everything back on...the heater should start to work. This would verify the filter just needs to be cleaned.
If you need help with the filter please add a comment with the filter details.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
May 19, 2011 | Raypak 130,000 BTU Natural Gas Pool...
I have a haywood h series h 400 pool heater. Each night the the pool pump timer runs b/t 12-7am.. The heater was working fine. and pool temp is around 70-80.. However, lately the heater which is on when...
Allheaters run off of a thermostat just like the heat to your house. It will shut off once heated to the selected temperature. Turn up the temperature, and monitor it for a couple days.
Dec 28, 2010 | Hayward H-series Electronic Gas Pool...
I have Jandy RS4 system with 4-button poolside controls for additional spa control. Inside house control panel stays totally lit up saying ''Rev 6700'', and cannot communicate or control pool operations. ...
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Oct 07, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heater runs 5-10 minutes then blows the breaker
After raising the water level in the pool I had no results. I bypassed the pressure switch and nothing happened so it was not the switch. Then I turned on the current for a few minutes, this moved something as it works now. So I conclude that the problem came from letting my water level get a little low.
Mar 26, 2009 | Raypak Spapak Electric Spa Heater - Els552...
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas  Logo
315 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
