How many ounces of refrigerant should a 2005 GMC 1500 van with rear ac take...at 30 ounces and cooling but not real cold..gauge reading about 35 but last 12 ounces didn't make it go up much?...thanks
  • 3,361 Answers
35 to 40 psi would be normal. If you are not cooling well you may have a bad compressor.
Posted on Jul 22, 2009
Magic chef french door fridge only cools on the bottom
If you charged the unit yourself the only thing I can think of is that you did not charge it properly. Refrigerators are not like AC units - the amount of charge, measured in ounces is very critical. You have to be right on the money lest it not cool properly.
If you have access to gauges and you are using the AC refrigerant normally used for cars, the pressure at ambient room temperature of 78 degrees should be around zero. Let the unit run for about thirty minutes to stabilize pressures and then do the reading. If room temp is higher than 78, then pressure can be a tad higher but no more than oupounds.
If no gauges, then allow unit to stabilize and then observe the temperature and condition of the suction line to the compressor. On a properly functioning unit the line should be cold to the touch and maybe sweating or beading. If it is warm to the touch you are low on refrigerant - add small amounts slowly till pipe cools. If you have frost forming on the pipe going to compressor the unit is overfilled and you have to bleed it slowly till it is cold and wet, not covered with frost.
Insufficient cooling is also caused by a improperly working freezer defrost mechanism whereby ice accumulates in freezer compartment. Here the culprit is either the defrost timer and or defrost heater element.
Nov 24, 2013 | Magic Chef Refrigerators
Ac won't work
is the cluch kicking on on the compressor?
Mar 17, 2013 | 1990 GMC Sierra
What are the AC pressures supposed to be on a 2000 Monte Carlo?
On hot day @ 85=+ degrees it should be between 45 to 50 pounds on the low side pressure port
Jul 01, 2011 | 2000 Chevrolet Monte Carlo
When you change from heat to air , it still blowes hot air like it is not switching to air conditing, the compressure is running and lines get cold, but no cold air. thanks
If the orifice filter is clogged, this will happen, a better check can
be done with an ac manifold gauge set, the low side reads the
evaporator pressure and the high side reads the discharge
pressure. I had the same problem while checking the ac on a
2000 gmc 1500 z71 4x4. other things that could cause this are
to much oil in the ac compressor or not enough freon in the
system. an overcharged system , the best way to check it is with
a gauge that way you can tell if you have the right amount of freon
and oil in the system. plus the gauge set will let you know the
extent of your problem. good luck!
Apr 06, 2011 | 1999 Chevrolet Silverado 1500
I can't find the fuel filter location for my 2005 GMC 1500 Van.
most gmc vehicles install the fuel filter under the truck in front of the rear wheel well.
Feb 01, 2011 | 2005 GMC Savana
2005 terraza never gete cold enough. in hot
It is hard to diagnose the problem with out knowing readings on the ac system,a low and high pressure readings would need to be known.This is needed to know if it is a internal ac system problem,or a vent door,or temp door problem.Have a mechanic put a set of gauges on the ac system to determine what is going on with the system.
Jul 20, 2010 | 2006 Buick Terraza
AIR CONDITIONING REFRIGERANT
Front A/C 1.8 lbs (0.81 kg) Front and Rear A/C 3.1 lbs (1.41 kg)
Air Conditioning Refrigerant R134a P/N 12356150 U.S. (10953485 Canada)
Jul 22, 2009 | 2005 GMC Savana
2002 GMC Savana 2500 Front AC warm, rear AC cool/cold
Typical symptoms of being a little low on refrigerant.
Oct 27, 2008 | 2000 GMC Savana
1997 dodge grand caravan a/c
What are the readings on your A/C service gauges, hi and low sides? If you don't have service gauges, inexpensive ones can be purchased at stores like: Harbor Freight, Walmart, Pep Boys, etc. The gauge readings are the first step to a correct diagnosis.
Your system may be low on refrigerant. If you also have a rear heating unit, the air mixing door or water valve may not be shutting off. Your expansion valve may be bad in the rear unit.
If you can access your rear a/c, check to see if the inlet hose is hot or cold. If it is cold, you are low on refrigerant. If it is hot and the tube coming out of the expansion valve/orifice is cold, this is the way it is supposed to be. If the tube on the outlet of the evaporator is not cold, then you are low on refrigerant or the expansion valve/orifice may be bad.
Jun 08, 2008 | 1997 Dodge Caravan
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
