Question about Craftsman 25cc Gas Line Trimmer
The pull cord mechanism does not engage. no parts
The pull cord mechanism does not engage. no parts appear broken in the mechanism.
Honda snowblower HS520 pull cord doesn't engage. Looks like there was an item in fixya addressing this at one time, but I can't find it. Any help?
in the recoil section of the motor ( where you pull the cord) there is a small tang that flips out as you start to pull and locks into the top of the pulley
if pulling the cord is not engaging the motor , it is most likely that the tang is broken or stuck in the returned position
may just need a bit of wd-40 or the like or if a new part , any mower repair or honda spares will have the part
Jan 05, 2017 | Garden
Why wont the pull cord on my snowblower pull
Can only think of three things
1 Bound rope/ broken mechanism
2 Trans or auger engaged
3 Engine seized
Good luck
Feb 23, 2015 | Garden
Rear wheels wont engage on a awd pontiac vibe
check the operation of the centre diff and the drive mechanism and oil levels.
Feb 12, 2015 | 2006 Pontiac Vibe AWD
Pull cord engaging
recoil clutch fingers are broken or stuck. Take the recoil cover off and look at it while pulling the cord to see if the fingers arent coming out. If the fingers are still coming out then you have worn out grooves on starter cone where fingers engage to turn the motor. If the recoil is damaged a new one can be purchased as a unit from Troy Bilt online for a reasonable price.
Jan 25, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Pull cord wont spin the motor
The engagement "dog" is probably rusted in place. Try spraying WD 40 on the recoil mechanism as you pull the starter cord
Jun 27, 2012 | Garden
When I pull the pull cord on my snowblower it doesn seem to engage the starter. the cord retracts after I pull it. It was working fine when I used it yesterday, then today it doesn't seem to catch when I...
Hello, W/D here.
Most of the recoil starters have ball bearings in them, and the centrifugal force that you apply pushes the balls out where they engage pawls and allow the flywheel to be rotated. Since your's is on a snowblower, you may just be stuck, or moisture could be in the mechanism, freezing the ball bearings in place.
The quickest thing to try: Rap the recoil mechanism in the middle of the top, with a rubber hammer. You want to jolt it, without denting it. Try to pull the cord and see if it engages. You can repeat this several times, but try not to dent it.
If the machine is outside, and you believe that the mechanism may have frozen, you can apply heat to it with a hair dryer, and then rap and try.
Try these out and repost if the problem persists.
Best regards, W/D
Feb 03, 2011 | Garden
Pull cord wont engage on weed eater
remove the cover and check to see if any of the plastic or nylon parts in the rewind mechanism are cracked or broken or if there is dirt in the re-wind pawls...clean and lightly oil, should work if not broken.
Jul 06, 2010 | Homelite Garden
Automatic Cord Rewinder is not rewinding anymore
I had the same problem - the power cord for my Hoover Elite Upright (U5507900) was stuck a few inches out and wouldn't go any further. But when I unscrewed the rewinding mechanism, the cord had clearly gotten twisted and partly buried under itself so after some work I was able to free it. Now it seems to be working fine, at least for the moment. Note that I had to use small screwdrivers to unscrew the cord rewinding compartment, like the kind of screwdrivers you use for computer repair.
HTH!
May 27, 2009 | Hoover Elite Rewind Bagless Upright...
Starting issues. Can't pull cord.
Make sure your flywheel brake is not engaged or the cover is hindering the mechanism somehow after it is installed
May 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
TB144 pull cord does not catch, pulls free--no start
yes exactly what i would do sounds like the springs are either worn or gummed up or just broken on the dog ears
May 11, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Craftsman 25cc Gas Line Trimmer Logo
209 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
