Question about Refrigerators
Ice sticking to ice maker
My side by side refrigerator ice maker keeps having ice getting stuck in the tray and causing the ice making process to stop . What is causing this?
  • Anonymous Mar 13, 2014
    My hot point refrigerator is cooling but not making ice in the ice tray.
  • 213 Answers
The water valve in the back where the water line conects is not letting the right amout of water pressure up to the ice maker. either valve is bad or if you have a filter it may need changing
Posted on Nov 20, 2007
  • acw768 Mar 08, 2011
    This is most likely and issue with the defroster on the bottom of the icemaker not working. It cycles with the ice maker to help the ice cubes get pushed out. Or you may have your cube size set too high. Remove the front panel and locate the adjusting screw. Twist it towards smaller cubes. If you surf around you can find these schematics pertaining to your particular model.
Ice sticks in the tray which causes the ice maker to not make enough ice.
Adjusting freezer temperature higher prevents ice melting and sticking together..
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ice maker doesnt make ice i have checked all the obvious stuff
Did you check the temperature of the freezer? Most ice makers have a temp senser imbedded in the tray/unit . If the temp in the freezer isn't at least 5 degrees (normally on many ice makers) the ice maker won't operate. This is one possible cause. Other causes could be no water to the tray, the timer motor defective or stuck somewhere in its cycle, or the bin arm is up in the off position. I hope I was of some help! Good luck!!
Nov 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool freezer on top ice maker is making a grinding noise and is not making ice Apiece of ice is sticking out of the icemaker's tray. we left it in the off position a couple of days. when we returned...
You should have three screws on the side of the ice make. Two right above the tray and one below. Remove the screws and unplug a four wire connector.
When you reinstall it check for proper water fill. A low water pressure to unit or ice maker valve getting plugged up can cause a small cube to get stuck.
Jul 28, 2009 | Refrigerators
Ice maker stopped working
if there is ice in the mold then the problem is the ice maker unit , replace the ice maker for the fix.
Phil
Jun 10, 2009 | KitchenAid KSRG25FKSS Side by Side...
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker over flow now water wont fill back up
no its not blown up low water pressure will cause also sticking water valves if it has worked properly for a while then change the water valves
Jan 29, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Kenmore side by side ice maker
in the freezer section where the front of the ice maker is a plastic face plate take that off and adjust the screw under neath it and ur problem can be solved
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker problem
Clear the Ice tray by pressing the button under the ice maker. The problem is that the ice is in the first couple of slots is not dumping and the tray tries to fill again and over flows. I pressed the button and cleared the tray of ice (This will tilt the tray and twist it to empty it) that was re-frozen several times without dumping. My ice maker works perfectly after I did the above. I think the problem arises if the door did not close completely. I stopped hanging the dish cloth on the door and on my LG Dish wisher. I hope this helps
Oct 03, 2008 | LG LRSC26940ST 36" Side-by-Side...
Ice maker stuck
Switch the ice maker off then back on should reset it . It is possible that the 'ice mould heater' is not working so the ice cubes don't realease from the mould , jamming the motor. Replacement ice maker is usually the solution
Aug 22, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Cube maker stops making cubes as they are being made ....
Ice makers use a small heating element to release the ice from the mold tray..sounds like that isn't working and everything else is. Check to make sure all electrical connectors coming from the ice maker are properly seated into their mating connectors. If that doesn't solve your problem, you may be better serevd by just replacing the entire icemaker assembly.. Hope that helps...
Jul 25, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
1,943 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
