Install fresh batteries.
Press reset button on left side of door (may be covered with protective plastic cap), beep will sound.
Enter new 3-8 digit code, press * or # key, green light will come on to confirm new code accepted.
Manuals are available at https://www.sandleford.com.au/sandleford-manuals
I have locked my safe I think by entering the wrong code. can you please advise how I can set a new code.... I cannot find the book that came with the safe.... thanks
Check the pin inside the connection (end of the cord) which you put into your machine, or check if the power connection on the circuitboard is damaged (you are able to wiggle it a little bit around)
Dell computer use the pin inside the connection from the adapter to recognise if the adapter you are using is a dell adapter or not. If the pin is damaged, or you are using an adapter from another brand. You will not be able to charge, but only power your pc.
you have a battery for the wrong model, I think they also changed the configuration of the same model number so that it had to be returned for proper service.No matter what you do a 3 pin wont fit a 5 pin socket.
