Blower fan does not always come on when the outsid
Indoor fan does not always come on when the outside unit comes on.
m/n- A32-10
Does this sound like a fan relay problem? If it does, what is the part number for the part?
  • 614 Answers
This a goodman unit and know you have a bad fan relay insid. Get it replaced or you can replace it yourself. You have to get the exact replacement for it to work right. It is actually a sequencer single pole double throw. They go out all the time. Russ
Posted on Jul 22, 2009
Concept 1000 ac unit. Fan comes on but no air come into the house and the line freezes outside next to the unit. I'm lost!
Check your indoor air handler unit. If the coil is frozen, it is usually one of two problems. You are low on freon, or your filters are clogged and not allowing enough airflow over the coil.
Mar 20, 2017 | Heating & Cooling
The control for the compressor is not turning on when the remote is set on cool, but the indoor fans turn on. This is a C4822N outside unit and a RS 2422A twin indoor unit. there is 220 volt being sent...
Never look at color of wire they could be anything. Always check voltage. Does outdoor contactor have 240 at one side or other of contactor? If so then its either bad t stat loose wire or lost charge and like a pressure switch is doing its job. Also transformer fuse on board etc..
Jan 29, 2018 | Sanyo Split System Air Conditioner
AC unit wont work, inside coils are hissing but outside unit not turning on.
If thisnis a central air conditioner and there is hissing at the indoor coil then the compressor is running, it is possible that both fans are not running. The indoor motor may not run if the control board is bad, capacitor is bad or the motor itself is bad. The outdoor fan may have a bad capacitor or the motor itself is bad
Jul 23, 2012 | Heating & Cooling
How to defrost the air condioner. It is froze up.
Hello my name is Heath it will be my pleasure to assist you. First thing to do is turn the unit off and check the filter then if the filter is okay check to see if the blower comes on when you put the fan switch on the thermostat from auto to on. If the blower isn't coming on then there could be a problem with the blower motor. If the motor is running then turn the system to cool and turn the setting down to where the air should be on. Then check the outside unit and be sure the outside unit is running if the outside unit is not running go to the house panel box and check the breaker to see if any of them are tripped or off. If there off turn them on and check the outside unit again. If all is running and you get no air flow through the vents then the coil could be frozen. If the unit is frozen turn the thermostat to off and leave the indoor blower on by leaving the fan switch in the on position for a couple hours till it thaws. If the unit froze up then there could be a problem with the a/c system most likely low on refrigerant as a result of a leak. I would have it leak tested and repaired if this is the case.
Sep 03, 2011 | LG Electronic Window Air Conditioner
There is ice on the grill and it is not giving cooling
Sep 02, 2011 | Mitsubishi Heating & Cooling
My unit to my house wont turn on outside. This happened last night at about 8:30. I have checked the circuit breaker/fuses and the little red switch on the unit itself-- I pushed that. I turned the...
Turn power off to indoor unit. Remove red, yellow and green wires from tstat and wire nut the three together. Turn power to indoor unit back on. This should bring on indoor fan and outdoor conpressor and fan. Let me know
Jun 22, 2017 | Fedders Q Chassis A6Q10F2A Air Conditioner
I have a coleman outdoor split system the indoor unit has two cooper pipes at the bottom the larger one keeps forming ice around it.
Aug 27, 2011 | Coleman Heating & Cooling
Hi I am Armando and I have a LG AC Mo # LSN180CE and I start to hear a bearing rattle noice right after the compressor, seems to me like it. The evaporator is like 20' o 25' away inside of the room, the...
First of all confirm where the sound comes from whether from Indoor or out door. If from indoor, the blower bearing worn out/ blower wheel broken.
If from out door, fan blade broken (replace fan blade)/compressor internal sound(replace compressor)/compressor seating bush worn out.(replace new bushes).
Helpful.
Jan 21, 2011 | LG LSC121PMA Split System Air Conditioner
The line coming into my indoor unit gets iced up. The ice extends the length of the line out to where in connects to the outside unit.
Icing in door due to 1. Less rpm of indoor fan motor (Replace capacitor or motor). 2. Indoor coil and blower wheel, filter dust blocked. (Service the unit). 3. Short of gas. ( Find for leak and arrest. Then vacumise and do gas charging)
Dec 24, 2010 | LG LS122CE Split System Air Conditioner
It froze up today and it sounds like something is trying to start but it never really gets going then it seems to power down, outside fan unit seems to be working ok.
That would be your indoor blower motor. It is either a bad motor or the capacitor is bad on it. Replacing them are never fun. The unit is freezing up because there is no air flow going across the evaporator coil when the outside unit is pumping refrigerant through the system. Hope this points you in the right direction!
Aug 04, 2010 | Heating & Cooling
Heating & Cooling Logo
100 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
