Question about Garden
Does not run at full peak speed
When blowing with full throttle it appears to not be at full speed
  • 32 Answers
Needs the carb adjusted H screw needs to be turned counter clock 1/8th of a turn try that when it is running and the throttle full
Posted on Jul 23, 2009
Machine bogs down in high speed operation
Hi Chris:
Just a couple of ideas:
- Make sure the fuel filter is clean.
- Make sure the air filter is clean
- Make sure the muffler is not plugged with carbon
- Make sure the spark plug is in good condition and gapped properly
- Reset the high speed mix screw after the previous are checked.
At full throttle, screw in until RPM peaks and then drops. Back out until peak, then 1/3 turn more.
Should run like a mad thing.
Cheers.
Feb 09, 2016 | Garden
Saw starts runs good then when i start cutting it
Hi Jason:
Make and model might help but here's two ideas:
1) Remove muffler and clean it. They can get plugged up with carbon and the saw will run at low RPM but will quit because of excess back pressure when you try to rev it up.
2) Set the high and low speed carb settings. Start the saw then gradually increase engine speed until full throttle. Screw the hi-speed needle in slowly. If RPM immediately drops, back it out until Rpm increases, then starts to drop. Screw back in until peak rpm reached, then starts to drop. Back out to peak, then 1/3 turn more.
Set low speed so engine runs smoothly but chain does not turn.
Hope this helps.
Feb 01, 2016 | Garden
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
Fuse blows repeatedly
The auto speed control is failed. Keep it manual and see how it does...It will run at full throttle even when no load is running. Then fix the throttle control when able.
Aug 09, 2009 | Generac Guardian Ultra Source 15,000 Watt...
2001 V Tech engine runs full throttle in neutral or in gear
Look under the hood. Look for the throttle body .The accelerator cable is attached to it. The cable housing anchor is broken and not letting it return to idle speed.. Use a portion of a clothes hanger to
secure the cable housing to the throttle body.
Apr 04, 2009 | 2001 Mercury Sable
5 HP troy bilt chipper sherdder will not rev up under load
Either or do one of two things if the motor runs pretty well Start the engine and run it full throttle. Once there if it has a high speed jet turn the screw in to start with until the engine stumbles a bit and then turn it back about a half turn. When you turn it in you should here the engine peak out. .If it is blowing black smoke out the exhaust it means the high speed screw is to far out so turn it in until it smooths out.If the engine smooths out then you have cured the problem. Good luck.
Mar 18, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
TUNING THE CARBURETTER
Start with the L or low speed screw at one turn and the H or high speed screw at two turns. To get good responce from idle play with the low speed screw. For top end engine peaking use the high speed screw. Hold the throttle wide open and turn the screw either way till you peak out the RPM'S . Hope this will be helpful. Donnyb60
Mar 18, 2009 | Echo Garden
Ryobi 31cc lawn trimmer carb adjustment
As with all 2 strokes if you have compression and a reasonable spark, you only need fresh fuel with correct oil ratio) and they must go !(as long as you haven't fiddled first and all gaskets are sealing) I start mine by(1) pumping the primer till it is firm,(2) full choke,(3) pull till it kicks ONCE,(4) half choke, pull till it runs,allow to warm up and(5) switch to run (you may need to apply a bit of throttle while pulling as in (4)(or give it a few more pumps if it dies) If all is ok, check that when properly warmed up there is a smooth transition from idle to full revs, if it hesitates it may need the LOW SPEED mixture leaning (clockwise) SLIGHTLY.If it dies the LOW SPEED mixture may need richening(anti-clockwise)(adjust 1/8 turn at a time) Make sure that motor is just peaking at full revs and is on the RICH side of peaking (HIGH SPEED mixture)(this will avoid seizing it Adjust both till it revs cleanly and is JUST rich at full, and idleing nicely and it should start without too much trouble.(If you have fiddled and are lost,-about 2 1/2 turns out from closed on both needles should get you started)
Nov 23, 2008 | Garden
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Garden Logo
236 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
