SOURCE: Outlet pressure?
have you tried turning the pressure adjustment knob clockwise to increase regulated, not tank, pressure
SOURCE: Hi! My hot water taps from the wash hand basin and
In a word no. Combi boilers work on balanced pressure.ie the mains cold supply to the boiler should be around 1 bar minimum which would give a hot water pressure of the same 1 bar. Assuming the cold water pressure is fine, it sounds like you have a restricted flow on the hot side. If you live in an area with water problems the hot water systems pipework calcify over time effectively reducing water flow. Unless any flexi hoses are kinked, check if there are any filters in the appliances that may be blocked.Also check all valves are fully open and if possible check if there are any restrictions at the valves. Failing all that and the taps are in good order it is possible to fit a pump before the boiler but this may only be a temporary fix overall.
SOURCE: Trips GFCI outlets
The motor on this unit is sealed and not accessible for repair, only replacement.
SOURCE: Im not getting any pressure (other than hose
Your problem is going to be with the brass fitting with the spring that you have discribed. This fitting is called an unloader valve, this valve is designed to by-pass the pressure that the pump has built up so you don't damage the pump when you release the trigger. There should be a nut on the end of this valve try turning it in some if this doesn't work try turning it out. It is usually set at the factory but sometimes they either don't get set or they are bad. You also could try to remove and clean. re-install with a light coat of white lithium grease. Hope this helps, let me know how you make out.
SOURCE: water doesn't flow through pump
the valving inside are stuck did you lube it before storing for the winter?
