Your low beams are controlled by the Vehicles BCM - body control module . The BCM energizes the HDLP LO/HID relay located in the under hood fuse box , sending B+ voltage to fuse's # 12 & 16 both 20 amp . LO HDLP - LT & LO HDLP - RT , These are B+ voltage for low beams . Your headlamp low beam relay could be bad or if the BCM isn't energizing it could be a switch problem . Do you know how to do basic automotive electrical testing using a volt meter . Videos on youtube ,plus video's on reading wiring diagrams .You can find free wiring diagrams at http://www.bbbind.com/free_tsb.html Also watch testing relays
SOURCE: 1993 Chevy Silverado truck headlights high beam only works no low
dimmer switch has gone bad need to change your dimmerswitch
SOURCE: Headlights wont work on 2000
Check the fusible links under the hood. Also, double check the bulbs are in fact good. Lastly it could be a defective daytime running light relay.
SOURCE: 2002 S10 CHEVY TRUCK. LOW BEAM LIGHTS NOT
The most common problem is the DRL-- or Daytime Running Module
HEADLIGHTS NOT WORKING
It
can be faulty headlight switch or issue with its wiring. Or its faulty head
light fuse.
To
troubleshoot the issue i suggest you few help links with appropriate solution.
So you can follow the test and confirm what exact problem is there in your case
of headlights not working:-----
Click
the link below: -----
http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
• Working of Headlight switch?
• Both headlight bulbs blow together?
• Car
headlight bulbs don't last long?
http://technoanswers.blogspot.in/2012/06/2007-dodge-caliber-low-beam-headlight.html
http://technoanswers.blogspot.in/2012/04/2001-chevrolet-tahoe-both-low-beam.html
http://schematicsdiagram.blogspot.in/2012/04/low-beam-headlights-modification.html
How to Replace a Headlight
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight.html
Bulb
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-bulb.html
Switch
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-switch.html
How to Replace a Headlight Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-assembly.html
How to Replace a Park Light Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-park-light-assembly.html
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-door.html
http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
These
will help.
Thanks.
