Question about LG Xenon GR500 Cell Phone
Dropped it in water, what do i do? - LG Xenon GR500 Cell Phone
  • 43 Answers
There isn't much you can do except:
Make sure it is off
Take out the battery
let it dry for 2-3 days
And hope. DO NOT try to turn it on if there is any moisture left in it. Keep it in a warm, dry place for 2-3 days with the battery out and hope that it works afterward. There isn't much that can be done to repair water damage to electronics.
Posted on Jul 22, 2009
The descaling light and water drop is constant flashing preventing machine from working, what to do?
Did you check if your hot water know was fully closed
Try turn off the machine, press the water drop button and turn on the machine . Keep pressing for 20 sec.
You may attached a recording video if problem not resolved
Good luck
Nov 12, 2014 | Saeco Odea Giro Plus Coffee Maker
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 09, 2014 | Water Heaters
What will happen when you drop a banana in some water will it have the same effects as when u drop potassium in some water
Short answer, No.
The potassium in a banana is not in the same concentration nor is it purified.
It is similar to how karoseen come from crude oil. a match in the oil will simply go out. The karoseen on the other hand will burst into flames.
Jun 21, 2014 | Sony Cyber-Shot DSC-W570 Digital Camera
Hoshizaki model AM50BAE not dropping ice...
Replace water float and check water inlet valve. with water constantly filling sump tray it will not make ice water will never cool down to 32 deg.
May 26, 2012 | Hoshizaki Cubelet Ice MakerDispenser Water...
2005pontiac grand prix with water in the gas tank
Your best bet is to drop the tank and then dump out the water. Dropping the tank isn't that big of deal. Remove the filler hose and a couple vacuum hoses. Unplug the main fue pump harness. Remove the fuel lines. Support the tank with an appropriate jack. Remove the straps and drop the tank.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Feb 06, 2012 | 2005 Pontiac Grand Prix
I dropped my phone and it could not on now
Due to hazard some phones are not working. If you dropped in water try with this steps.
  • Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. If you have dropped your cell phone in water, it is also helpful to disassemble it if you can and let all the parts dry separately.
  • If the phone will turn on, you can try to make a call to be sure it is working properly. If you put your water damaged cell phone back together and it won't turn on, it is likely that some water has gotten down inside the phone.
If dropped in floor, please bring it to service center for repair.
Jan 04, 2011 | Cell Phones
Water level drops in bowl after it fills
If very little water is used on initial flush, The bowl is functioning as a tank for second thorough flush. The high water level cannot stay high in the bowl while in motion or you would have a mess ion start and stops.
May 28, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Water pressure dropping
have you checked the saftety relief usually set at 30psi sometimes will stick open and if it piped to a drain you should look and see if there is water running into it. The only other thing is a leak in the system but usually will be noticable by water lying somewhere.
Jan 19, 2009 | Heating & Cooling
LG Xenon GR500 Cell Phone Logo
111 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
