Question about Mtd Garden
46 inch MTD Yard Machines lawn tractor variable speed drive very jerky at higher speeds especially going upgrade
4 Suggested Answers
  • 62 Answers
SOURCE: MTD TRACTOR FLIPPED UPSIDEDOWN; NOW IT DOESN'T START ???
Does the engine turn at all? If it does, the you probably need to replace your fuel filter, air filter, and spark plug.
On small engines, when they get turned over like that, oil tends to go places it shouldn't. Usually that means that your filters, and carburetor, and from there into your cylinder, fouling your spark plug.
Check those items, and replace any that have traces of oil in/on them.
Posted on Apr 17, 2009
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
huffman49
  • 235 Answers
SOURCE: MTD 46" Yard-Man Lawn Tractor battery connection problem!?
the battery for a garden tractor should have the holes already in it if not you can buy a clamp that you can use that has a hole for what you need. good luck
Posted on Apr 11, 2010
Where do 4 springs go on 46 inch deck? The deck diagram I have does not make sense.
Hi Nick,
This may be the same diagram you already have, but this is the manufacturer engineering drawing for that deck.
MTD 13RN771H729 Yard Machines Lawn Tractor 2007 Home Depot Deck Assembly...
Aug 17, 2014 | Mtd Garden
What sizes are the drive belt and mower belt on a 1999 agway mtd riding mower with a 12.5 hp briggs?
go to any lawn mower shop they will tell you and get you your belts 45.00 to 60.00 for a belt
Aug 11, 2014 | Mtd Yard Machines 38-Inch 12.5 HP...
MTD 42 INCH DRIVE BELT DIAGRAM
Go to MTD website and download the manual for your machine.
Jun 19, 2014 | Mtd 46" Dozer Blade, Fits All & Yard -...
My MTD 14hp lawn tractor (38", 6 speed) shuts of
You have a short somewhere . A cut or stripped wire that , at the time of lowering your deck, touches the body. It's like turning off your key. Look around under your deck and you will find what I'm talking about. Fix wire and tie up to prevent future problems. GOOD LUCK.
Jun 16, 2011 | Yard Machines MTD Gold 20 HP Lawn Tractor...
I HAVE A 1994 MTD 18HP BRIGGS WITH MOD #144Q828H118, WHILE I WAS MOWING THE CLUTCH WOULD NOT RELEASE AND THE GEAR SHIFT WILL NOT GO INTO THE LOWER GEARS. WHAT HAPPENED?
The tractor has a variable speed pulley for the 1-6 gears. You will want to check the top pulley on the shaft that is in the center of your tractor between the engine and transaxle. you may have broke the spring or adjuster.
Apr 24, 2011 | Yard Machines MTD Gold 185 HP Lawn Tractor...
Hi i just bought a second hand MTD C4510 ride on mower yesterday, and the drive belt came off , where can i view a diagram to fit it so it can drive forward etc
u should have two drive belts .go to nearest seller of mtd ,get owners manual .u can'not push foot speed lever to quicky up & down .start to learn how to use your mower slowly .there is no gear box for forward & reverse speed. but u have forward & reverse gearbox .talk to your dealer he will explain
Dec 10, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
Yard man mtd 20hp 46"cut hydrostatic drive lawn tractor,model"13AU69H401 deck belt need diagram to put it back on?
Jul 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Jun 28, 2009 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
I need a belt diagram for my lawn mower>
If you don't have the model number, I just found a diagram for mine by Google, by typing in "MTD 46 inch deck diagram" It took me to a Parts Tree site and right to the diagram I needed. There are slight model differences but for years, the 46 inch, three blade deck has been essentially the same.
Apr 26, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
1,148 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
