Question about Gigabyte GA-EP43-UD3L Motherboard
Flashed bios wont boot ga-ep43-ud3l
I flashed the bios and now it wont boot windows ga-ep43-ud3l how can i fix it? I also tried clearing CMOS and still nothing. PLease help
  • 433 Answers
Seems like your bios update failed, was corrupt, wrong version or was interrupted.
It's very difficult to recover from a failed bios flash , but if you are lucky you can try clearing cmos then take the battery out overnight. Then reinstall battery and do a HARD BOOT.
If that does not work try this site and read recent comments.
http://ask-leo.com/flashing_my_bios_failed_how_can_i_recover.html
Good luck,
Hank
Posted on Jul 23, 2009
GA-EP43 -UD3L motherboard will not boot with 16 GB of memory
Time to RMA, sounds like you have a faulty memory channel on the MB. Possibility the slots are not getting enough power to handle all 4, you try to see if you can increase power in bios.
Mar 01, 2017 | Gigabyte GA-EP45-UD3L Motherboard
I want to reset BOIS password for Gigabyte GA EP43 motherboard which has no jumper, i try to remove battery but the problem unsolved~
There is a CLR CMOS jumper on that MB next to the SYS FAN 2 connector by the IDE header
open = no clr
jumped= Clear CMOS
From the manual page 32
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
Jul 20, 2011 | Gigabyte GA-EP43-UD3L Motherboard
I bought a ep43-ud3l mobo that I installed with windows, after moving some files from my old hard drive windows became corrupted , boot up resulted in BSOD, erased windows bsod, formated HD BSOD, removed...
pls check the cpu compatibility. one time I tried to install 64bit , but could;t install. 32 bit was ok. check the video adapter and remove it and try it with on board vga
Jul 17, 2017 | Gigabyte GA-EP43-UD3L Motherboard
EP43-UD3L Sound problem
you will need to download the newest drivers for your motherboard, make sure you download the right ones for your operating system. I used to go to the manufacturer's website to do this all the time but now i'm lazy and i just google: (motherboard model) drivers download. By the way i don't ever mess with disks anymore because its bound to be outdated by the time you get it.. they make good coffee mug coasters though.
example: Gigabyte EP43-UD3L sound download
http://www.google.com/search?hl=en&client=firefox-a&rls=org.mozilla%3Aen-US%3Aofficial&hs=AMT&q=Gigabyte+EP43-UD3L+sound+download&aq=f&oq=&aqi=
Oct 29, 2009 | Gigabyte GA-EP45-UD3L Motherboard
GA-EP43-UD3L Reboots while loading Windows
its due to bios problem , upgrage bios from biostar web
Oct 26, 2009 | Gigabyte GA-EP43-UD3L Motherboard
Disk error when booting.
Enter your BIOS, then check the setting under Boot Sequence.
If the first boot device is HD/Harddisk, then you havn't any proper OS intalled.
If not then change it to HD then check.
Kindly Do Rate, If Helpfull.
Jul 17, 2009 | Gigabyte GA-EP43-UD3L Motherboard
GA-EP43-UD3L Having problems installing motherboard. Will not boot. Phase Led lights flash on then off. Help
CLR_CMOS (Clearing CMOS Jumper) (next to the battery)
Jun 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Gigabyte GA-EP43-UD3L Motherboard Logo
455 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
