Question about Refrigerators
Fridge not working properly
All of ther sudden all the food in the fridge froze. Temperature awas not changed. Can you suggest what could have caused this and a possible solution...Thanks ... Steve
  • 2 more comments
  • jools46 Apr 12, 2008
    I have the same problem the fridge keeps freezing I have tried adjusting the temperatures but it still freezes Help
  • Jen272 Oct 04, 2008
    Ok, this may be a stupid question, but I've been talking to my friends about this and we're still not sure what is wrong: No matter which level I put the cooling control to (even if it is on zero) everything in my fridge freezes.
    The lid on the mini freezer compartment broke off a while ago, but, while some of my friends say the lack of the lid would cause everything to freeze (due to the fridge trying to adjust its temperature to keep the freezer cold?), my other friends and myself are not so sure.
    If the lack of the freezer door is causing everything to freeze, what material do you recommend I cover the freezer compartment with? If the door has nothing to do with the problem, how do I fix the cooling controls?
    Thank you so much!
  • SwtCubana Oct 05, 2008
    Me too!  I have the frig. side set to zero.  If I move it up just past zero towards 1 everything freezes.  The milk and water on top shelf have gotten rock hard.  It had run perfectly for its 5 years with both sides set to 5.
  • j_oconnor3 Jan 20, 2009
    Are you referring to the the device where you set the fridge temp?
  • 213 Answers
The temp control got stuck during a cooling cycle if you replace the cold control it will solve the problem
Posted on Nov 20, 2007
Refrigerator not cooling
they have an air damper that sometimes fail too much food in them will cause them to not work properly also
Jun 21, 2016 | Refrigerators
Freezer has ice fridge is warm food going off
change the temperature sensor its not working fine
cause the compressor is working all time never stops
this is located inside a metal box with a dial
Sep 16, 2015 | Refrigerators
How can i operate the temperature of the haier fridge model hrf-660aa
do you hear the compressor come on? can u feel it vibrating? if not? bad relay maybe? is there power from the outlet? may also have a bad cold control thermostat or defrost timer? is ther any heat in the freezer compartment?
Feb 16, 2015 | Haier Refrigerators
My whirlpool fridge is freezing the food in the fridge. What is causing that?
adjust the temperature settings.change from coldest to colder
Jul 15, 2014 | Refrigerators
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
What temperament should i put on my fridge?
Most fridge manufacturer's suggest 34 degrees F (but no lower) for the fresh food compartment, and 0 degrees F (lower is O.K.) for the freezer.
Measure temperature on the fresh food compartment by placing a thermometer in a 6 - 8 ounce glass filled with cold water. Place the glass with the thermometer on a shelf in the fridge. Wait about an hour or two (assuming the door stays shut) and check temperature. The water is to minimize changes shown on the thermometer when you open the fridge door.
I hope this helps & good luck! Please rate my reply. Thank you.
Mar 29, 2011 | Food Processors
Fridge compartment is freezing food/milk etc
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 06, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Food in fridge freezing solid
Sounds like you need to replace the THERMOSTAT , aj
May 05, 2009 | Frigidaire GLRS267ZA Side by Side...
Freezer works great, as it should, but fridge is only keeping items room temp. I have the setting at the coldest setting: #7. What is wrong?
Here's what I did, I defrosted! I found out that the fridge temp is monitored and maintained by the freezer. Because we had a power outage one night, my freezer thawed while we all slept and then when power came back on, freezer re-froze but this cause an ice build up on the vent on the back wall of the freezer. Well, ice must have been in one (or more) vents, causing blocked air flow in my top half of the refrigerator. I turned the dial in the freezer to "off" which also shuts down power to the fridge half. I then unplugged the refrigerator, hauled all my food items into coolers, opened the freezer door and refrigerator doors and left them open for a little over six hours. I took advantage of this empty fridge and freezer and wiped everything down. After this time frame passed, I plugged the fridge back in, turned the freezer dial to my preferred freezer temp, and wah-lah! Within two hours I had a cold fridge and solid ice cubes in the freezer. I then put all my food items back into their appropriate compartments, and went to work. Bear in mind, a total 24-hour period is needed for the fridge to re-set itself, but still, after two hours the fridge was noticeably cold. Who knew, besides our parents' generation: DEFROST!
Sep 10, 2008 | Maytag MBB1954G Bottom Freezer...
Refrigerators Logo
456 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
