Question about Whirlpool Duet GHW9150P Front Load Washer
F02 with good pump and clear filter... now what?
Was getting beep with F02... read this and went to the strainer at the pump. additionally removed and cleaned all hoses. bought new pump with attached strainer. Even removed and cleaned the black boot with the ball float and still Beep with F02... what now????? can put wash in maint mode and drain fine with both old and new pump... once it drains, its like the pump just keeps running until SUD and/or F02 appear, HELP!!
  • 1 more comment
  • vtx1800ghost Jan 04, 2010
    It is not a detergent issue... I solved the problem. there is a vacuum pump on the back of the dryer. this vacuum tells the control panel if there is water in the drum... if the vacuum sucks and has pressure, then there is water in the tub to pump... once the water pumps out, the vacuum no longer feels presure so that means the tub is empty... the problem is this... if the vacuum pump is clogged, then the vacuum always thinks there is water in the tub and keeps the pump pumping... then the error... clean out the vacuum pump in the back of the system and guess what, the vacuum no longer has a problem....
    It's not the detergent... I figured it out on my own... there is a vacuum pump in the back that was clogged with "gunk". when the vacuum is clogged, the system thinks there is water in the tub even when the water is completely pumped out.
  • erica graber May 11, 2010
    are you using HE detergent?
  • 15,935 Answers
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^%#$
Posted on Sep 29, 2010
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 06, 2014 | Whirlpool Washing Machines
Tip
F02 Code
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F02” error code.
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
If the pump motor or impeller becomes damaged and does not pump at the correct volume, the error code will not clear. If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
on Apr 05, 2010 | Washing Machines
Tip
F02 Error Code
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
on Dec 09, 2009 | Washing Machines
Display flashes F 2 at the 1:00 minute to finish time and stops and beeps.
F02 error means if the drain time has exceeded more than 8 minutes. After four minutes suds will be displayed on the screen and again after 4 minutes the F02 error code appears.
Check the drain line for any clogs or blocks which hinder the draining procedure..Use of more detergent can even cause this condition..Be sure you are using only 2 tablespoons of HE soap and not more than that.
Check your drain filter also and replace them if needed. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer. The drain/filter/pump is right in front.
Feb 03, 2011 | Kenmore HE2 Plus Front Load Washer
My whirlpool duet frequently locks up. It flashes f02 or SUD or just sits and does nothing. Sometimes it takes over an hour for a 40min cycle. Today I used the washing machine cleaner in it on the...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We are getting an F02 reading. The hoses are
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display. Check the drain hose and make sure it is not plugged or kinked. Check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. If the above does not correct the problem, replace the pump.
Jan 06, 2010 | Kenmore Elite 45986 Front Load Washer
F02 code on Whirlpool Duet Washing Machine
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^%$
Aug 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite F02 code even after changing to a new pump.
remove compartment cover under the front load door. There is a drain there that will catch large items left in your clothes, ie pens paper etc
Apr 01, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore H3 doesn't agitate or drain reads F02
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&!!
Dec 09, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite - F02 trouble
Hi jbll,
The f02 code is always from a slow drain issue. This washer allows only 8 minutes for all the water to drain and if it is not gone in time you get the F02.
This is the proper check sequence for that problem.
Check the drain pump filter for foreign objects. You can remove this easily and replace it if needed.
I hope this has helped, Lots of luck . Mike Anderson
mca0824@aol.com
May 02, 2008 | Kenmore 4292x Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
176 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
