Question about GE Ovens
Cannot go above 350 degrees
Do you have an owner's manual that we could get to know how to operate this range?
  • Anonymous Mar 25, 2014
    propane range broiler only operates at above 400 degrees
  • 867 Answers
If the burners turn red when turned on, there is a thermostat issue or electronic control on newer stoves. if burne does not turn red, it needs to be replaced
Posted on Jul 22, 2009
I have a frigidaire range model number FEFL78CQA
Hello Steve Spinner - From what you have described it sounds like the range is either experiencing a wiring failure or the outlet may be damaged. Could it be pulling too much current, is the range plugged into the correct breaker size? If any proves to be ineffective, contact a professional to move forward accurately.
Dec 01, 2012 | Frigidaire Ovens
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
Help! I am renting an apt (and the owner is overseas) and the oven/range which came with it is an older Caloric Prestige series (gas range and oven) with self-clean feature. It has been cleaned so often...
Hello!
can you find information (sticker / label)in the body of the oven. It will be easy giving you information if you can provide the brand and model number of the oven.
Please post back!
Apr 10, 2011 | Ovens
I have an SL100 - 10W La Germania table top oven (gas) I did not receive a operations manual with purchase of the oven and I do not understand its operation. Questions 1. How does it maintain the set...
I GOT THE SAME QUESTION .. IT IS A GAS OVEN . WHEN THERMOSTAT IS SET TO GAS MARK 4 WHICH IS EQUIVALENT TO 350 DEGREES , AFTER 10 MINUTES, IT REACHES ITS DESIRED TEMP. BUT IF I DON'T ADJUST THE FLAME, THE TEMP WILL RISE HIGHER AND HOTTER THAT I NEED TO OPEN THE OVEN DOOR TO DECREASE THE TEMPERATURE INSIDE. ANYONE KNOWS IF THAT IS NORMAL? THANKS12_1_2012_3_54_19_am.jpg
Oct 26, 2010 | Ovens
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
Oven shuts down before reaching correct temperature
You will need to check the oven calibration using a thermocouple based thermometer(the one you stick in the oven is not reliable). Electric ovens should keep a near constant tempature so if you have it set to 350 the oven should stay around 350 once temp is reached. Now gas ovens are a little different. Most use a on/off thermostat and that means the temp can vary from 320 degrees to 370 degrees to keep an average tempature of 350. So if it is a gas oven you will need to let it warm-up for 10 minutes then start taking the lowest and highest 5 consectutive readings. Then add the 5 reads together and then divide the number by 5 and it should be within 10 degrees of the set tempature. If it is off by more than 50 degrees then you might not be able to get it back to proper calibration. The calibration methods are different for each range and depend on the type of thermostat you have digital(push button controls) or manual(knob). The owner's manual for your range might contain the instructions or consult the manufacture's website for the instructions.
Dec 21, 2009 | Whirlpool Ovens
F1 when bake on oven is 350 degrees.
You also have a defective electronic control. Replace the clock.
Aug 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Need instructions on how to program all ten buttons for different temperatures for we have no manual that shows us how. We manually programmed button number 1 for 350 degrees F and it works, but can'
http://www.langworld.com/lang_cd/Operate%20Manuals/CNVTOVEN/Op%20Convections.pdf
Check out this web site for your manual. The model EHS-APM is not listed but there are other units with multiple programming options. You will have to browse somewhat but what you are looking for is probably there.
Good Luck and hope this helps.
May 17, 2009 | Lang Manufacturing EHS-APM Electric Oven
F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
Nov 03, 2007 | GE JTP20 Electric Single Oven
Fridgidaire stove/ove
I have a Frigidaire electric oven model # PLES389ECE. It is two years old. It has maybe 50hrs of use. I had the oven blower motor go out. Then I had a circuit board malfunction.  The repairman discovered that one of the main terminal connections was loose and caused the terminal block to short. Could this have been the problem all along? Also, we are having a problem with the oven coming up to temp. According to the operating manual, set oven temp. lets say for example  350 degrees. Once the oven is preheated to 350 a beep sounds. With my oven the oven is about 60 degrees to low. You have to wait about 10 more minutes. Is this normal with this model? Has anyone else had problems with this model? I also heard that Frigidaire made a bad batch of ranges. Could this be one of them?
Thanks, Vincent
Oct 27, 2007 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
51 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
