Roller won't roll. It keeps breaking belts
SOURCE: I have a bissell powerforce bagless vacuum. My
Its probably is the roller brush causing the noise.
SOURCE: My roller bush won't turn ever time i put a new
1) you need a little tight the belt, with the bolts of motor.
2) you must shure if the belt if NOT large or short( in both cases the rollers will NOT run. can be slip. or too TIGHT. and BRAKE the motor.
3) the motor you must test for brush, switch, or open winding.
4) put a little lube in the extreme of shaft rollers,see by turning at hand if they run of course unplugged the power cord.
God bless you
SOURCE: My Bissell powerforce bagless turbo roller will
Hi Hiram. The brush will continue to spin when you're using the upholstery hose. You may want to set your height adjustment to the highest setting and leave the handle locked in the upright position.
Here's a quick link to downloading the User Guide if you need a copy:
