Question about Dell 3000cn Color Laser Printer
Vertical lines printed on right side of every page
This printer has been nothing but trouble. It is less than 1 year old and has printed very few pages. Now all pages come out with 2 vertical lines on right side of page. I have replaced toner cartridges. I examined the drum and see marks that appear to line up with the lines. What would cause this and what is the fix? I see posts about replacing the drum, but my drum is not near old enough.
    Problem Solver:
  • 8 Answers
Would be helpful to know the brand and model of the printer. Sometimes this is caused by not returning the slide used to clean the primary corona wire to its original position (usually to the extreme left side of the toner cartridge) after cleaning the corona wire. If you haven't cleaned the corona wire, you should follow instructions and do that first.
Posted on Jul 22, 2009
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
Canon LBP 2410 Lazer Colour Printer -
Printing not dark enough or varied in darkness
If the print is a dismal gray rather than a sharp black, you are probably almost out of toner. This can manifest itself evenly across the entire page or in splotches or stripes, depending on the printer.
Sometimes you can wring a little bit more out of a toner cartridge by taking it out and gently shaking it from side to side (never up and down, as toner can spill out). You can also try turning up the printer’s contrast adjustment, if it has such a knob (usually on the back side if it exists). Faded print can also result from a dirty corona wire, because a dirty wire inhibits a full electrical charge from being passed.
If the printouts are consistently varied in density, and you have to frequently remove the toner cartridge and shake it to redistribute the toner inside it, make sure the printer is sitting on an even, flat surface.
Horizontal black lines
A horizontal black line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant black lines on the page and then use Table A to determine which part might be causing the problem. Table A
Distance between lines
Faulty part
0.5”
Registration assembly
1.5”
Upper registration roller
1.75”
Lower registration roller
2.0”
Toner cartridge developer roller
2.56”
Lower fusing assembly roller
3.16”
Upper fusing assembly roller
3.75”
Toner cartridge photo drum
Regularly spaced splotches
If there are evenly spaced black spots but they don’t extend all the way across the page, the problem is probably a scratch or flaw in the drum or a build-up of toner on the fusing roller. If the spots are less than three inches apart vertically, it’s probably the drum, because the drum has a larger diameter than the fusing roller.
Vertical black line on edge of page
This can indicate an almost empty or faulty toner cartridge or (less frequently) some spilled toner inside the printer.
Jun 07, 2008 | Canon Office Equipment & Supplies
Printer prints off the side of the page
Hp2600n Colour Printer Colou Problms
Feb 14, 2014 | Lexmark E332n Laser Printer
I would be calling Lexmark about this because this is not a user serviceable issue. If you are down to measuring the size of boxes that it prints out and they are not right, I would want to see what the issue is and how to fix it.
Mar 06, 2017 | Lexmark E332n Laser Printer
Vertical blank "line" on printed material.
try the toner cartridge. You can see where its coming from by printing 1 page. When the page starts coming out of the machine open the cover. Take out the toner cartridge and look at the page. The line should be there and you should be able to figure whats causing it. It's almost always the toner cartridge. If you have an old cartridge put it in and run a test with it. If the line is gone its the cartridge. Steven 818-888-0006
Mar 06, 2010 | HP LaserJet 1100 Printer
When printing a document for 1 pages only it will come in two pages
Take a look at the document in the application. Does it allow you to roll to a second page?
Next, check to see what your bottom margin is on the page. If it is less the 0.25" than you may need to increase the margin size because you are getting into the "No Print Area".
When the application tries to put data into the no print area, the printer rolls the data to a new page.
Also, you can change the vertical spacing between lines to a smaller amount. This will cause the vertical lines to shrink together.
Don
Feb 16, 2010 | Minolta Di152 Laser Printer
Old canon copier prints thick balck line down right side of paper
tthis is really old 25 years plus. replaced the drun cartridge which also contains the toner good luck canon sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
Vertical stripes
It sould be the print heads have gone bad.
I just had a Dell color laser that would print a 1" wide yellow line down the right side of the paper.
Replaced the print head unit, and problem solved.
Jul 29, 2008 | OKI C5100n Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Dell 3000cn Color Laser Printer Logo
341 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
