Question about Boston Acoustics BA745 Computer Speakers
Subwoofer is the subwoofer supposed to be so quiet? mine barely makes a peep.
  • 305 Answers
No the subwoofer resinates the low base frequency sound, but it should be loud enough to be annoying if its turned up, check your connections, , you should also be able to feel the vibration from the woofer.......if connections are ok, it may be defective
Posted on Jul 22, 2009
Is the air blend door supposed to make noise when opening and shutting. I just had mine replaced in a 2004 explorer at the dealer
Yes. I would be concerned if I didn't hear it operate. The sound of the louver opening and closing is more noticeable when the inside of the vehicle and the outside environment is quiet. The sound should become less noticeable as the blend door breaks in with use.
It is made of plastic it will find its fit and quiet down.
Oct 29, 2014 | 2004 Ford Explorer
Phillips subwoofer circuit board
can you give some idea about this protector ic no C1237HA?
Jan 16, 2014 | Audio Players & Recorders
Hello i have a s master digital amplifier model number SA-WSF200. Suddenly the right speaker a subwoofer stoped working. I tried plugging the right speaker into the left speaker output on the amp and it...
i dont know if amp has fuse for each channel, but they would be easy to see.. otherwise that baby has a blown component or two on a pc board, maybe an output power transistor of capacitor failed.
Last time i went to a shop it was like $100 plus parts for a similar repair.
I recomend sending Sony support an email and see what they say before you take it anywhere as well..
Dec 04, 2013 | Audio Players & Recorders
Samsung ht q-20 quiet at full volume after kids were playing with it. All speakers work just barely audible at max volume. Help!!!
First, check to make sure all wires are plugged into the correct location. If the problem persists try changing the amp or play source that you are using to see if it is a problem with that. Their is sometimes a secondary volume knob on the speakers as well. Hopefully this helps.
Feb 15, 2012 | Samsung Audio Players & Recorders
I just noticed the right speaker is very very quiet compared to the left. It still puts out sound but its very weak. Is this supposed to be this way or is something wrong? I've only had these about 2 weeks...
It might just be the song..try playing different ones, if it's still the same then check the connections, and the settings on whatever you have plugged into them. The balance may be set to the left.
Jan 31, 2011 | Philips SPA2360 21 Speakers
The subwoofer is wired in perfectly but only works quietly in the "input" on my head unit it is a twin 12" edge subwoofer
Please explain more. I don't understand what you mean by "only works quietly in the "input" on my head unit". Are you saying that you have the sub connected to something labeled "input" on your radio?
Jan 10, 2011 | Car Audio & Video
My friend just installed my subwoofers into my car. They are Dual 12 inch 1100 Watt speakers with a Pyle 1400 watt 2 channel amp. He installed his own speakers in his car so i trusted him with mine. He...
your getting fead back. check the ground on the amp it needs to be bare metal and tight also check the rcas they need to be tight and if its only hapening wile u play the ipod try switching wires from the i pod it hapens all the time with aux cables they break easy.
Sep 28, 2010 | Dual Car Audio & Video
Why want my subwoofer play like it's supposed to? It barely plays
check your ohm load on that audiobahn sub some amps run at an bypass or ohm load and then kick off if its the sub itself is not a 2ohm stable or 4ohm stable
Mar 03, 2010 | Car Audio & Video
Amp is on, but sub wont produce any bass
Make sure the subwoofer is set to low frequency, make sure subwoofer and bass are enabled on the headdeck. Make sure the gain is turned up on the amp, make sure the rcas haven't come out of the back of the head deck.
Aug 04, 2009 | JBL GTO14001 Car Amp
Timex Expedition, beeps very quietly and indiglo doesn't work.
To clarify... Replace the cover with the arrow on the back pointing directly at the stem. The Indiglo backlight, alarms and chimes should all work when the back cover is in this position.
May 04, 2008 | Timex Expedition 40141 Wristwatch
Boston Acoustics BA745 Computer Speakers Logo
296 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
