SOURCE: Is it possible to update Samsung 1500 so that it
At this point in time, the 1500 cannot stream from Netflix.
SOURCE: blu ray want connect to the internet
You have to buy a Samsung wireless adapter in order to use a wireless conection..look up your player at www.avsforums.com for any and all questions and answers.
SOURCE: i have a SGH-A767 SAMSUNG mobile no internet connection
The best way is to call your carrier and get them sent to your phone automatically. To enter them manually:
T-Mobile Browser/Java Settings:
Connection name: T-Zones
Gateway IP address: 216.155.165.050
Secondary IP address: Blank
APN name: wap.voicestream.com
Data bearer: GPRS
Profile name: GPRS
Username: Blank
Bearer: Data
Home page: http://wap.myvoicestream.com
T-Mobile MMS Settings:
WAP Gateway IP Address: 216.155.165.050
APN Name: wap.voicestream.com
Homepage or MMSC URL: Messaging Server: http://mms.msg.eng.t-mobile.com/mms/wapenc
Data Mode: Connection Oriented
AT&T Browser/Java Settings:
Connection name: Internet GPRS
Data bearer: GPRS
Access point name: wap.cingular
User name:
Prompt password: No
Password:
Authentication: Normal or Secure
Gateway IP address: 66.209.11.61
Homepage: http://device.home
Connection security: Off
Session mode: Permanent
AT&T MMS settings:
Connection name: Multimedia
Data bearer: GPRS
User name:
Prompt password: No
Password:
Gateway IP: 66.209.11.61
Homepage or MMSC URL: http://mmsc.cingular.com
Connection Security: Off
Session Mode: Permanent
SOURCE: connecting to netflix cannot find the location on
You need to connect to netflix via a PC or a Mac to get the access code for the Wii.
Go to your Wii menu, download and install the Netflix application from within the Wii Shop Channel, and follow the on screen instructions to connect your Wii to your Netflix account.
To connect via Wi-Fi go to the tutorial at
http://www.nintendo.com/games/wifi/wii
SOURCE: the Netflix app on my
I had the same problem with my Vizio XVT473SV. I couldn't find the Netflix Activation Code. When I clicked on the Netflix App, the TV would ask me if I wanted to connect to Netflix, then it would ask me if I was a Netflix member. After clicking yes to both, it would tell me it couldn't connect to the Netflix server, check with Netflix.com/tvhelp. After a couple hours of troubleshooting, the solution was......your first use of the Netflix App has to be via the Ethernet Port/Cable. This will give you a screen with the Activation Code, after you activate the code in your Netflix account, you can go back to using WiFi on your Vizio TV to connect to Netflix. Step by step instructions are...
1) Exit the Vizio Netflix App.
2) Physically connect an Ethernet cable to your broadband (just temporarily)
3) Check to make sure the Vizio is using the Ethernet port and not your WiFi (Apps Button - HDTV Settings - Network...may have to reboot the TV to get Ethernet port connection)
4) Start the Vizio Netflix App
5) Click OK to start the Netflix App
6) You should now see a different screen that gives you the Netflix Activation Code.
7) On your Computer, Login in to Netflix,
8) Click on "Your Account & Help" link on upper right corner
9) Scroll down to Watching Instantly on your TV or Computer section
10) Click on Activate a Netflix Ready Device
11) Enter the Activation Code shown on your Vizio TV and click Activate
12) Once your Netflix account (on your computer) shows it is active, your Vizio TV will automatically log in. You should see your Instant Queue.
13) Exit the Netflix App, unplug the Ethernet cable, Turn Off your Vizio TV.
14) After 20 seconds or so (remember the TV is software driven), turn the TV back on and your WiFi should connect again.
15) Use your Netflix App and this time it should automatically connect via WiFi
note: just make sure that your wireless DSL/Cable Modem or Wireless Router is not blocking your WiFi connection request from the Vizio. You can check the connection status in the modem/router or in the Vizio in the HDTV Settings - Network.
