Question about Dryers
Ge spacesaver dryer 120vac, doesnt get very warm, takes hours to dry. do i need a new heating element?
    President:
  • 1,124 Answers
A wat to check if the element(s) are working..
Take the exaust hose off.. Put a mirror to see in there.. The eliments should be glowing hot when on..
Rate well ;o)
Posted on Jul 22, 2009
    President:
  • 1,136 Answers
Hi, The most common reason for the dryer to long to dryer is the venting. Make sure the vent is open all the way outside and the flap in the vent hood is working properly. Make sure the vent is not pinched off.
please let me know if this helps you at all.
Thanks
Vic
Only gets warm and takes hours to dry
Could be a defective heating element.
Mar 02, 2015 | Dryers
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
Hours to dry. I have a GE Profile Wizard model DPSE592EA2WW electric dryer that barely gets warm and takes hours to dry a single load.
as i do not have diagram of your dryer i can only guess for you,(i am not an expert.) The element is usually in the back of the drum (at air intake). Air is blown in, heated, then goes out the opposite side where it is vented.does it heat any better at another temp setting, say MED. opposed to HIGH? This may help temporarily. Replacing element isn't hard if you are mechanically "handy", but you may first want to consider the the age of the dryer, cost of a new part, and your time. Often a used dryer is a worthwhile alternative. To replace:Remove screws to remove back panel. The heating element should look something like a flat hair dryer (basically that's what it is).If your lucky your part will come with instructions, but this would be the exception. The unit should slide or clip to plug in and out. Screws aren't usually used in this application.IF YOU HAVE A MULTITESTER, AND THE KNOW HOW, YOU CAN CHECK FOR CONTINUITY AND RESISTANCE THROUGH THE TEMP SWITCH. This will give you an idea if the element is your problem. It should be one of the two. Hope I've helped.
Dec 27, 2011 | GE Profile Wizard DPSE592EAWW Electric...
My Bosch electric dryer wta3510uc heats but doesnt get hot like other dryers. why is that? it takes over an hour to dry or even more and it use to seem much hotter. clothes are still cool and damp after 40...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
GE DNXR47GW1WW Dryer is extremely slow to dry clothes (takes over 2 hours per load). The dryer does heat. Any suggestions?
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective. (if this is a gas dryer, please disregard this statement)***
Jun 16, 2009 | GE Dryers
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
GE dryer will not dry towels
How warm is "warm"? If the clothes are warm to hot after 15 minutes of running but not gettign dry, you do not have a heating element problem. Sounds like you still have an air flow problem. Does the heating element cycle often? You may have lint clogged at he entrance to the blower. This would be out of sight from the exhaust. Try removing the exhuast hose and running it in air-only and feel the amount of air leaving. It should feel like a lot of air coming out. If not, you will need to check the condition of the blower. I had this same issue and ended up pulling the blower cover off and pulled out a very large amount of lint..it was almost completely clogged. Afterwards it drys really fast! Good-Luck.
PS If you do not feel comfortable accessing the blower, you should have a professional do it for you.
Mar 23, 2009 | GE DVLR223 Dryers
It now takes 2 hours to dry towels
lets hit the eazy button first.dry a load with out the venting[wont hurt a thing]if ok its the house venting,if not dryer .GE is only brand that has two elements.so if not ge and heating element ok and its blockage in the dryer.hope that helps God bless ,tom
Jan 04, 2009 | Dryers
Maytag dryer doesn't dry properly
heating element is fine. it either works or it doesnt, cant work halfway, your problem sounds like you hav a clogged vent a kinked exhaust leaving the home. try looking at the exit point form the home can you see any lint around the housing, VENT VENT VENT
Mar 11, 2008 | Dryers
Dryers Logo
47 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
