Question about Refrigerators
My bottom refrigerator is not cold. The freezer is okay.
My bottom refrigerator is not cold. The freezer appears to be working okay. What can be some of the problems? How can I fix it myself? Thanks.
I'm a maintenance man with the city housing.I have the same problem with magic chef refrigerators of not getting cold on bottom.I found out sometimes when drain in freezer box gets block when it defrost the water builds up then freeze up blocking the vent hole stopping the cold air from reaching the bottom compartment.Solution Turn off refrigerator drop the thermostat housing in bottom compartment and clean drain.Then remove rear freezer wall disconnected fan than manually melt ice build up in freezer coils and bottom vent hole with hot water boil it in a small pot for quicker melting time..Pour on coils until ice melts.make sure you put a pot inside bottom compartment to catch water when you melting the ice on coils and vent hole.When ice is melted.Turn back on the refrigerator hook back fan.And test coil heater manaully turn heater timer and see if the heater comes on.If it's ok start putting everything back together.Set your thermostat.Note this want I do when I'm in a tenant apartment on a repair.If you got time and just leave the both refrigerator door and let room temperature melt the ice.Which can take hour's.
Posted on Mar 25, 2012
  • 670 Answers
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Posted on Jul 22, 2009
Bottom fridge has stopped working. Top freezer is okay. Fridge light is working and thermostat is making operating noise, just no coolness.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 26, 2011 | Avanti FF510 (5.1 cu. ft.) Top Freezer...
Temperatures not staying cold, then getting too cold. First everything in freezer thawed out. Then, fridge wasn't cold enough. We moved everything to freezer just to keep colder (not to freeze). Then, days...
assuming fan now working. clean out vents/ drain holes (make sure no ice in bottom of freezer or in fridge unit)i.e. a total defrost.then check door seals all okay(no air leaks) if unit was trying to defrost itself and you reset to colder it will need to reset itself.....
Feb 11, 2010 | Hotpoint HSS25GFP Side by Side...
Refrigerator is not getting cold although the freezer appears to be working fine
can you hear the evaporator fan motor running in the freezer? this fan motor pushes the cold air from the freezer to the food section to keep it cold. you may have to replace the evap. fan motor. also, check for any kind of ice build up around the evap fan motor.
Oct 11, 2009 | Amana ABB1927DE Bottom Freezer...
My KitchenAid KBRS22K bottom mount refrigerator is eight years old. Was working fine, but now the refrigerator does not cool, but the freezer stays cold. The fan seems to work and the coils have been...
the problem here is the defrost element is not coming on, the problem is the control board in the fresh food compartment is defective and not telling the element to defrost. Therefore your cooling coils are impacted with ice which keeps freezer cold, and sensor in freezer says everything is ok and therefore sends nothing to refrigerator. Replace the defrost control board, Thaw out the cooling coils in freezer, and your back in business
May 19, 2009 | KitchenAid KBRP20EMSS Bottom Freezer...
My refrigerator is too cold
sounds like you have a defective temparture sensor
Apr 07, 2009 | Samsung RF265AA Bottom Freezer French Door...
Refrigerator not cold
first check your damper door from the freezer to the refrigerator compartment make sure its in the proper position. Then turn off the refrigerator for a few hours until the heavy frost melts away. turn on the refrigerator check the refrigeration cycle, is it working properly, is it going into defrost are the defrost heaters working.
Feb 21, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
GE GDS18LBP bottom Freezer - Refrigerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
dl;
Feb 17, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
FRIGIDAIRE REFRIGERATOR
what line?
is the freezer cold?
model serial number?
May 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Zanussi fridge freezer
sounds like the freezer evaporator has iced /frosted up and you will not get cold airflow through it. try a 24 hour defrost to clear it. then check fridge cooling.
Jun 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
201 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
