Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Water leaking from unit
My ProHeat Pro sucks up the water fine but there is a leak somewhere and I wind up loosing the water.
  • 410 Answers
Press the foot lever to open the upright fully. The flexible suction hose that stretches when you open the handle gets damaged and will need repaired or replaced. I usualy take the clamps off, cut off the damage and re-fasten up higher. Dale.
Posted on Jul 22, 2009
Bissell 9500 ProHeat, Why is it leaking water from the dry air vent?
The only thing I have seen cause anything like this is a high suds level in the waste water container. Usually caused by using pre cleaners on spots on the fabric. Those pr-ecleaners, i.e. Resolve, etc. create a LOT of excess suds in the waste water that can be sucked up in places they shouldn't be.
Jul 06, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell proheat pet will not suck up water
Check the filters. User's Guide has locations. one under water tank cap one under Flow Indicator. They are small but need to be cleaned after each use.
Jul 18, 2014 | Bissell Pro Heat Orginal belts
Bissell 7920 ProHeat Upright Carpet Cleaner leaks soap
Just prespray with a pump up sprayer and use unit to extract only with hot water.
Apr 07, 2014 | Bissell 7920 ProHeat Pro-Tech Upright...
After cleaning the heater, my unit now leaks when it's turned on.
Hi there. Sorry to hear you're having difficulty with your ProHeat 2X leaking. You may want to contact one of our Authorized Service Centers to have a qualified technician inspect your machine.
Here's a quick link to help you locate one: http://www.bissell.com/service-centers/?cid=ccsocial
Aug 11, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 12 amp turbo carpet cleaner, not sucking water, model#8910
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Apr 15, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell proheat 7901-1 steamer won't **** up the water
Sounds like either the pump is not working or the collection unit has an air leak.
Apr 01, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
My bissell want **** up the water My Bissell proheat 12 amp is blowing and not sucking up the water and dirt. What am I doing wrong?
somewhere on the unit, there will be a round clear cap. when you find it, unscerw it and clean out the inside.
Mar 01, 2009 | Bissell 1699 ProHeat Clear View Upright...
No dispensing of water from container.
Check the bottom of the tank, there should be a gasket on the valve at the bottom of the tank. Must be on the tank and not sitting in the hole. Make sure the tank is sitting firmly and not off set even a little. Loosen the cap for the flow indictor while running, then tight when fluid starts leaking out, stop when the spinner starts spinning. Other then that you may have a clogged line somewhere.
Jul 08, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Water leaking out from bottom of 7901
That part can go bad, but I have found more often the a water line came loose. Take out the 6 screw and the flow indictor cap, remove the top, then inspect that area. If you find what the problem is, fix it then when you put the top back on, make sure the piston is on the bottom of the smart mix valve and that the knob is in the water only spot, then push the top back on. If you need to replace the auto-load receiver, the part # is 2140710 and you can order from a local repair shop.
May 30, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
188 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
