Question about Dryers
Will not run
Will start to run but after u let go of the on button it stops running u keep on pushing it it will finally not do anything until u wait for alittle bit then the same thing i replaced the on and off switch
    President:
  • 1,136 Answers
Hi, The drive motor is going bad. It has a bad start winding in it.
If you will get me a model #, I can look this up for you and get you part #'s and pircing.
Thanks
Vic
Posted on Jul 22, 2009
I have a Candy GOU218 when I push the start button it does start the dryer but as soon as I release my finger from the button it stops, It started doing it around a week ago so I had to push and hold
There are push to start circuits used for motors and then there are holding circuits that keep the unit running. This way the dryer stops if the circuit is open due to high temperature or end of the cycle. It seems as if the holding circuit (could be a rotary switch that stays closed while the dryer is running) or a holding circuit relay (stays closed until circuit is broken by the control) has failed.
Jan 09, 2014 | Candy Dryers
My cannon scanner MP240 is getting an error E5 please help to find out the solution
Error ink cartridges are not installed properly (Error E5)
First power off the printer. Next, while holding STOP/RESET button, power on the printer.
While holding POWER button, release STOP/RESET button. Then push STOP/RESET button twice.
Wait about 20-30 second until the LED shows "0?. Then push STOP/RESET button four times.
Finally push POWER button twice. Last step is to turn off the printer by pressing the POWER button one last time.
Jul 07, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Dryer only runs when "push to start" lever is held. stops when you let go. is this the motor switch causing this?
In a normal situation, when you push the start button, it activates the relay to hold on the circuit until it is interupted: for example you open the door. The relay cannot activate by itself until an initiation by the push button. If the relay is not working to hold the current then then holding the button to keep motor running is what happenes here. Your relay need to be replaced.
Jul 09, 2009 | Dryers
Whirlpool dishwasher stops at rinse cycle and won't go
Aureley, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Aureley), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 18, 2017 | Whirlpool 24 in. GU980SCG Built-in...
What do these codes mean on 1994 Cadillac Eldorado -A012 and A047
Sound like you have a bad cv "constant velocity joint " REPLACE.
The first thing you need to do is to clear your old codes then drive
and see if they come back .
1. Re-enter back into the climate control panel and after all the codes display the display will stop at PCM?
2. Push and release the FAN UP (^) button on the climate control panel and you will see PCM DATA?
3. Keep pushing and releasing the FAN DOWN (v) button until you see PCM CLEAR CODES?
4. Push and release the FAN UP (^) button and you will see PCM CODES CLEAR?
5. Wait 5 seconds and then keep pushing the OFF button until you see PCM?
6. Push and release the FAN DOWN (v) button and you will see IPC?
7. Push and release the FAN UP (^) button on the climate control panel and you will see IPC DATA?
8. Keep pushing and releasing the FAN DOWN (v) button until you see IPC CLEAR CODES?
9. Push and release the FAN UP (^) button and you will see IPC CODES CLEAR?
10. Wait 5 seconds and then keep pushing the OFF button until you see PCM?
11. keep Pushing and releasing the FAN DOWN (v) button and you will see ACP?
12. Push and release the FAN UP (^) button on the climate control panel and you will see ACP DATA?
13. Keep pushing and releasing the FAN DOWN (v) button until you see ACP CLEAR CODES?
14.Push and release the FAN UP (^) button and you will see ACP CODES CLEAR?
15. Wait 5 seconds and then keep pushing the OFF button until you see PCM?
16. keep Pushing and releasing the FAN DOWN (v) button and you will see SIR?
17. Push and release the FAN UP (^) button on the climate control panel and you will see SIR DATA?
18. Keep pushing and releasing the FAN DOWN (v) button until you see SIR CLEAR CODES?
19. Push and release the FAN UP (^) button and you will see SIR CODES CLEAR?
20. Wait 5 seconds and then keep pushing the OFF button until you see PCM?
21. Push the AUTO button to get out of diagnostics.
22. Turn ignition OFF for 15 seconds.
23. Re-enter diagnostics and see if any history codes re-appear.
Mar 27, 2009 | 1994 Cadillac Eldorado
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Finalize a CD
Put the cd back and press finalize...Wait a minute until finalizing time is displayed...After that press the pause button and it will start finalizing....It will count down until it is finished...
Jul 21, 2008 | HHB BurnIt CDR830 CD Recorder
Machine keeps doing one step of cycle and beeps
Hi there.
There may be a problem on the control board (you suspected yes?)
Or it may be waiting for a certain condition.
Basically it's a very simple computer.....-
Select program (sequence of events)
Water fills.....Untill weight sensor says stop.
Water then heats........Untill temperature sensor says stop.
Goes through a sequence of motor spins....untill time out.
Pumps out.....untill floatswitch says empty.
Does same again ...or something else.
Either the control board has a fault - so just doesn't advance, or there is a faulty sensor that never supplies the info needed to advance.
Try and spot at what point it stops and waits. This will pinpoint what it's waiting for.
If it's waiting to heat up - and the element has blown. it will be stone cold. This is a common fault.
Let me know how you get on.
Richie.
Jun 14, 2008 | Washing Machines
Stereo stopped responding
1. While in Demo mode push and hold the "PUSH-MENU" button until "set" appears on the screen.
2. push "Seek" + or - to select Demo
3. turn "PUSH-MENU" to select "demo off"
Oct 30, 2007 | Aiwa CDC-X204 CD Player
Dryers Logo
Top Dryers Experts
