Question about Kenmore Elite HE4 Electric Dryer
Hi, my kenmore elite dryer 110.66942500 took a power surge. Replaced 240v AC outlet at wall (burnt) and matching cord. i have 240 at the red and black on inside of unit. Won;t turn on, drum lite out... replaced controller board and thermal fuse, still no drum lite. I am thinking it is the timer now thoughts??
jsrock516
  • 5911 Answers
SOURCE: No nothing! -Kenmore HE3 DRYER # 82826
Unfortunately, the Main Control Board generally is the culprit that kills the entire dryer on these models. The tech sheet you discovered should also give you the test points to check the control panel too. However, if the Main Control Board is bad, it will do you no good to try to trace voltage if it's not there. In addition, the connector pins are so small it makes it rather difficult to even try to get good resistance readings. Now...to rule out other possibilities: THERMAL FUSE - Would kill all dryer functions, but I believe the control panel would still work and the interior drum light would come on. THERMAL CUT-OUT - Would only kill the HEATING portion of the dryer. The drum would still rotate, but the unit would not heat. DOOR SWITCH - Control panel would still function, but dryer would not start and drum would not rotate. BELT SWITCH - This will shut down a dryer if yours is equipped with one. I don't believe this model has such a switch, but even if it did, the dryer would not start, but the control panel would still light up. So...other than double checking all your wiring to make sure you don't have anything broken or loose, you have probably narrowed it down to the most likely cause. You still might have a defective interface panel, but they don't fail as often and are more expensive. Generally, the whole panel has to be replaced. I hope this guides you in the right direction. If you need further assistance, post comments.
Posted on Aug 18, 2007
Jimster
  • 240 Answers
SOURCE: Timer on dryer counting down too fast
Now that there is a good one. Everything you are saying leads to a control board failure. Did you replace the board yourself, or have someone else do it? I have before gotten a new control board of the shelf, and it be as bad as the one I was replacing. Just a thought. Let me look around and see if I can find some other information, just really sounds like a bad part.
Posted on Feb 15, 2008
Master_Tech
  • 770 Answers
SOURCE: Thermal fuse
remove the bottom paneland look y the heating element there should be a mini manual down there with a wiring diagram
Posted on Aug 16, 2008
  • 744 Answers
SOURCE: either the thermal fuse or the ignitor on my kenmore elite gas dr
Remove the lower front cover - it has spring-loaded keepers that can be gently pryed and the panel should either hinge down or pop off. The thermal fuse and ignitor are behind this panel.
Posted on Mar 29, 2009
jsrock516
  • 5911 Answers
SOURCE: dryer won't turn on, outlet works, cord works, but nothing works!
Read through the following link and make sure you rewired the dryer correctly:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you have questions, please let me know. I hope you find this information helpful.
Posted on May 12, 2009
I have a Frigidaire smooth top range. Burners heat, EOC as no power and thebake and broil elements therefore can't be turned on. I ordered and replaced the EOC. I am getting 240 volts from the wa
I'm assuming you're in the US, and the regular power outlets should have 120v AC.
Check your neutral at the power outlet. Between any of the 2 hot wires (your 240v) and neutral there should be about 120v AC.
If the neutral there is ok - check continuity between a white wire in a 6-pin plug on your board and neutral on the range plug.
If all ok there - check continuity between a black wire which connects to "L1" on the board and black wire from the power cord at the terminal block.
Good luck,
Vlad, First Choice Appliance Service in Sacramento, CA
Jul 06, 2012 | Kitchen Ranges
Dryer has power but will not start. tested wall outlet and dryer plug and both have power. blower motor and heating element both read 120v ac.
Assuming this is a full size 240v dryer (you never said what it is) you should have 240 volts across the two angled prongs in your receptacle (L1 and L2). 120v across either ONE angled prong to the "L" shaped prong (neutral).
If it a 120v dryer your voltages are alright.
It sounds like the door switch is open.
Jan 03, 2010 | Kenmore 500 6953 Dryer
Can't turn wii back on
Did you unplug it from the Wii, or from the Wall Outlet? You need to unplug it from the wall outlet, not the Wii. If you haven't unplugged it from the wall outlet and left it unplugged for 5 to 10 minutes, then unplug it from the wall outlet and leave unplugged for a good 5 to 10 minutes.
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself, so power to the AC adapter needs to be cut off.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
Dec 08, 2009 | Nintendo Wii Console
No Power with dryer plug in
Plug light or something into wall outlet to see if you are getting power.
Got power then check for power at power cord inside machine.
Check power at timer.
If there is power at timer then circuit testing come into play.
Jun 09, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 Dryer PF on control panel,
HI, there may have been a slight power failure within the home breaker unit or the dryer may have lost power to the control for some sort of reason.
I recommend a thorough inspection of the terminal block on the back side of this unit. make sure the power cord is attached tightly and the wall outlet is secure and holding the power cord correctly. if everything looks great with the terminal block and the power cord is plugged in the outlet correctly, simply unplug this unit for 5 minutes to reset the control. after the 5 minutes are up, plug the unit in once more and the PF alert should reset.
Make sure the breaker box in your home is working properly. (the actual breaker switch for the dryer must be in the on position)
Apr 26, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
From three prong to four prong
Hello There,
your hooking up 2 Hots 1 Neutral and 1 Ground
240v
you need to consult a electrician for reason that 240 is a very high voltage and will kill you.
your outlet has to match your plug and how its wired into the Panel
Double Pole Breaker 50amp no less
2 hots go to breaker from outlet red / black
1 neutral goes to neutral bus bar in panel from outlet
1 ground goes to ground bus bar in panel from outlet
that equals your four wires
Mar 20, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore dryer model no. 110.85087400 won't start
hello
i have a kenmore model 110.85087400 that will not heat up i just replaced the heating element and still have the same issue.what do you think it can be...when i open it to replace the element i notice some lint that was burnt...help please.miguel
Aug 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
195 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
