Question about Canon imageCLASS D761 Copier
Coping but nothing on the paper has toner. Looks maybe like the exsposure light. Can this be replaced?
  • 40 Answers
Blank copy is usually a broken drum charge wire or transfer corona wire
Posted on Jul 23, 2009
Terrible copies down the sides !
759a6310-c94d-4cc9-8251-468d69129a1d.jpgIF IT LOOKS LIKE THIS, LONG STORY SHORT REPLACE BLACK IU
SEAMS TO BE TRIGGERED BY HIGH HUMIDITY
Jul 09, 2013 | Konica Minolta Magicolor 4695MF All-In-One...
My dell 1130 has a steady red light
Maybe there is problem with toner cartridge (maybe it is empty or problem with the chip), paper jam or some mechanical problem. Try to take out the toner cartridge and put it back. If the blinking still exist try to replace the chip (or refill the toner cartridge) or check for paper jam. Maybe there is small part of paper - look carefully.
good luck.
Good luck
Jul 24, 2012 | Dell 1130 Laser Printer
The "ready" and "alarm" light
Please do the cleaning of DRUM unit by sliding several time the blue lever. Maybe your charge corona unit is dirty with some dust or toner. Also power off and then on the printer. Check that everything is OK with paper path and tray.
P.S. DRUM UNIT has to be replaced after making a 20000 pages. If you don't want to buy a new one then it should be reset.
pifonski
Feb 19, 2011 | Brother HL 1440 Laser Printer
Printer light says paper jam but cannot find it. Almost have the whole printer torn apart and cannot figure it out. I copy the light comes on and paper only feeds in about 1/4 way. Then a real paper jam....
Did you remove the strip from the toner cartridge before you installed it? There should have been a tab to pull out a strip that looks like a long piece of tape. This prevents the toner from spilling out during shipping. It must be removed prior to use.
Dec 21, 2009 | Brother HL-2040 Laser Printer
I have a problem with my XC1020 copier. When I install a new toner it will make a few copies but then quits. I have tried 3 new toners so it must be something wrong with the copier that keeps knocking the...
Turn machine on hit clear button and hit exsposure button and then clear button and then exsposure button (fast) the display will go blank. type in 24 start 7 start. type in 14 and then start. then type in 16 start. turn machine offf and then on.
Sep 04, 2009 | Xerox Office Equipment & Supplies
Printer is not printing anything
Turn off the Printer, remove the paper tray in front, remove the toner and cover the toner with paper so light doesn't rain down on it! Take a flashlight and look inside to see if there is anything loose paper in the rollers or stuck inside. also look in the toner area too. Remove the rear cover also to inspect for objects. If all looks good then, unplug any cables going to the PC side. Wait 30 seconds. Then insert the paper tray first, the add paper to it. Insert back the toner Plugin back the power and then cables. Also Reboot the PC connected to it.
Now once the PC is back up and running turn on the printer. If you never done so update the drivers for the until form www.hp.com.
Jul 31, 2008 | HP LaserJet 1000 Printer
Not printing, making me crazy
A paper jam has occurred. To solve the
problem, see “Clearing Paper Jams” on
page 6.3.
• The front or top cover is opened. Close the
front or top cover.
• There is no paper in the tray. Load paper
in the tray.
• The waste toner container is not
installed or full. Check the container.
• Your system has some problems. If this
problem occurs, contact your service
representative.
  • Also i can indicate that the Toner Cartridges are empty and need replaced with Genuine Samsung Cartridges
Jun 17, 2008 | Samsung CLP 300 Laser Printer
Print paper
Not much,in most cases both can be switched, thermal is different, lasers use toner not ink, Premium inkjet paper has better ink asorbition properties with little spread, and paper designed for lasers can cope with the heat applied when it passes via the 180 deg fuser that melts the toner to it. Generally paper used in inkjets and laser is just standard 80gsm paper
Never use labels/transparentcy's designed for inkjets in laser machines they wont cope with the heat,
Jan 30, 2008 | Nikon COOLPRINT Thermal Printer
Minolta cs pro
if it's only on the top half of paper there is something more going on, the seperation assembly could be having problems where the paper as it goes through lifts up on the drum and gets dirty.
Dec 11, 2007 | Minolta EP1030/1030F CS/PRO Copier
Canon imageCLASS D761 Copier Logo
41 people viewed this question
old marine
old marine
