Question about Brother MFC 210C All-In-One InkJet Printer
Printing problem The machine could not print!
  • 832 Answers
So let me see into my magic glass bowl....;-)
Can you please give some more info about the printer problem?
Its helpful to know what solutions you have already tried out (cleaning cycles? Can you power on? Did you run a test print? Do you use 2nd party cartridges etc....)
Posted on Nov 20, 2007
Can't print from my pc
Reinstall the print driver. Does machine make copies, can you print from a different computer. try printing from different programs Outlook, word, adobe pdf. web page. CAN you ping the machine. does it show up under control panel under printer devices. Delete all print jobs from all computers or at the machine. Power off the machine. wait ten seconds power up.
Jan 14, 2014 | Konica Minolta Bizhub C554 Color Copier /...
AT2+ doesn't print
Its a common problem with Schiller ECG machine. The battery of your ECG machine is faulty. Even if you are using the machine in AC it uses the battery power. The AC power is only used for charging the battery.
When the machine starts to print the battery will drop down and the printing will stop. This is happening with the machine. It will eject the first paper without printing. its normal. Because the machine starts printing on a fresh page only. In your case the machine is ejecting the first paper. When the machine starts its printing in the second page it will draw a large amount of current from the battery for its thermal printing head. If the battery is not proper then it will suddenly drop the printing. The square box you see is not printed by your ECG machine. Its already printed in the paper of Schiller. With this mark the Machine sense the page.
Its a 12 volt 2.3 AH battery. You will not be able to replace the battery from out side any where. For replacing the same you have to open the machine by removing the screws on its bottom. Be care full with the paper tray while removing the top cover. Also do not use any force to open the top cover because there are connections on the top cover.
Here i have added a link to the battery for Schiller AT2 PLUS
Apr 27, 2012 | Schiller Welch Allyn Cardiovit At 2...
My printer has a problem picking up the paper and moving through the rollers in the back.
Paper does not feed
into the machine.
• Remove any obstructions from inside the
• Paper has not been loaded correctly. Remove
paper from the tray and reload it correctly.
• There is too much paper in the tray. Remove
excess paper from the tray.
• The paper is too thick. Use only paper that
meets the specifications required by the
You can print on a variety of print media, such as plain paper, envelopes,
labels, and transparencies. Always use print media that meet the guidelines
for use with your machine. Print media that does not meet the guidelines
outlined in this user's guide may cause the following problems:
• Poor print quality
• Increased paper jams
• Premature wear on the machine.
Properties, such as weight, composition, grain, and moisture content, are
important factors that affect the machine's performance and the output
quality. When you choose print materials, consider the following:
• The type, size and weight of the print media for your machine are
described later in this section.
• Desired outcome: The print media you choose should be appropriate for
your project.
• Brightness: Some print media are whiter than others and produce
sharper, more vibrant images.
• Surface smoothness: The smoothness of the print media affects how
crisp the printing looks on the paper.
• Some print media may meet all of the guidelines in this section and
still not produce satisfactory results. This may be the result of
improper handling, unacceptable temperature and humidity levels,
or other variables over which Samsung has no control.
• Before purchasing large quantities of print media, ensure that it
meets the requirements specified in this user's guide.
Using print media that does not meet these specifications may cause
problems, requiring repairs. Such repairs are not covered by
Samsung's warranty or service agreements.
Make sure not to use the inkjet photo paper with this machine. It could
cause damage to the machine.
May 16, 2011 | Samsung CLP 300 Laser Printer
The yellow ink will not print. There is definitely ink in the cartridge. I have tried the cleaning process 4 times.
  1. Print a Print Quality Check Sheet.
    1. Press the Ink or Ink Management button.
    2. Press the up or down arrow key to choose Test Print. Press OK.
    3. Press the up or down arrow key to choose Print Quality. Press OK.
    4. Press Color(Colour) Start.
  2. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
  1. The LCD asks you if the print quality is OK for black and the three colors. Choose No.
  2. The LCD asks you if you want to start cleaning. Choose Yes. The machine starts cleaning the print head.
  3. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
  4. Repeat the cleaning and the quality check process following the Step 7-9.
  5. Compare the second or third Print Quality Check Sheet with the first one you printed in Step 1:
    1. Press Stop/Exit.
Note We do not recommend frequent unplugging and re-plugging of the machine and/or leaving the machine unplugged for extended periods of time.
  • To maintain premium print quality, our product is designed to automatically clean the print head periodically. When the machine is unplugged, it will not complete the periodic cleanings needed to ensure ink does not dry in the print head and may cause poor print quality.
  • Machines with a Message Center or Fax Preview have a 24 hour memory backup. All other machines have a 1 hour memory backup. If a machine is unplugged beyond the memory capability, the clock data is lost and causes the machine to reset. When the machine is plugged back into the outlet, the internal clock resets and the machine will automatically start a cleaning process causing the consumption of ink.
We recommend using the On/Off or Power Save button to power down the machine. Using the On/Off or Power Save button allows minimal power to the machine ensuring periodic cleanings of the print head occur only when necessary and needed information remains in memory.
  • Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
  • DO NOT touch the print head. Touching the print head may cause permanent damage and may void the print head's warranty.
  • Brother strongly recommends that you do not refill the ink cartridges provided with your machine. We also strongly recommend that you continue to use only Genuine Brother Brand replacement ink cartridges. Use or attempted use of potentially incompatible ink and/or cartridges in the Brother machine may cause damage to the machine and/or may result in unsatisfactory print quality. Our warranty coverage does not apply to any problem that is caused by the use of unauthorized third party ink and/or cartridges. To protect your investment and obtain premium performance from the Brother machine, we strongly recommend the use of Genuine Brother Supplies.
    > Brother Genuine Supplies information
Oct 28, 2010 | Brother MFC-5890CN All-In-One InkJet...
Fax not printing correctly
Sounds like your print head is dirty if you are using a inkjet machine. Although you didn't say what machine. Your machine should perform a print head cleaning procedure if you turn the machine off and then on again. Otherwise you'll need to replace the print head which may or may not be part of the ink cartridge depending upon the machine in question - good luck
Jul 06, 2009 | Canon FAX-B820 Plain Paper Bubblejet
Machine will not print double-sided documents
Try resetting the NVRAM from the diagnostics screen.
Apr 09, 2009 | Xerox Phaser 8560MFP Laser Printer
Laserjet P4015
Unplug the cord that you are using to print to the machine.(USB, Ethernet). Clear the print que that is going to the machine. Power off then back on machine. Rehook up print cable and try to print again.
Hope this helps
Dec 03, 2008 | HP P4015X LaserJet Printer with Automatic...
Faxes printing from back
Your machine has a rear door that allows you to print out the back when you do not want the document to have to curl through the entire machine; IE transparencies or labels. Just clear the machine of any objects or jams and close the rear door and the machine will automatically print out the front again.
Oct 09, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother MFC 210C All-In-One InkJet Printer Logo
27 people viewed this question
James Cagle
James Cagle
Jim Keysor
