You will get no help until you provide the needed information, that is how it works, you can give me all the not helpfuls you want.You will get no help until you provide the needed information, that is how it works, you can give me all the not helpfuls you want.
You can't post conmments that contain an email address.
Yes it should do the job. You will need to wire the sub in series and make sure you have a 4ohm load on the amp. It should be right at around 700 watts RMS @ 12-13 volts.
In part yes it is a flexibility for wiring your speakers to match the impedance of your amp. For example if your subs are 2 ohm dvc by wiring them in parallel you can drop the impedance down to 1 ohm per speaker and if you connect two 1 ohm then you get 1/2 an ohm load. Or you can put them in series and increase the impedance to 8 ohms which I wouldn't suggest you do. Here is a link to wiring speakers:
Description
One of the oldest and most respected names in automotive sound is also one of the most consistent winners on the competition circuit. Lanzar offers a wide range of high performance subwoofers, from the pounding OptiDrive Series to the rugged MAX Series. The MAX12 dual-coil subwoofer offers high power handling, great bass response, an economical price, and a 3 year warranty. Specifications: *Power handling: 500 watts RMS/1000 watts peak *VCdia: 2" *Impedance: 4 ohms per coil *Magnet weight: 130 oz. *Fs: 33.6 *SPL: 88 dB 1W/1m *Vas: 3.19 cu. ft. *Qts: 0.47 *Xmax: 10mm *Dimensions: A: 12.09" B: 11.15" C: 6.42"
The only way to wire a single 4ohm DVC sub to present a 4ohm load is to just connect one voice coil. If you wire the coils in parallel, you get a 2ohm load. If you wire them in series, you get an 8ohm load. But it will work great with just one voice coil. Or if you really want to use both voice coils, and your amp isn't stable at 2ohms, wire the voice coils in series and present an 8ohm load to the amp. It'll work fine, it just won't deliver quite as much power.
