Question about Dishwashers
Door rubs on new tile floor. How do I fix this.
New tile are ready to install. As I was trying the tile to be sure the door jams were cut to the right height and to decide where to put the cut tiles pieces, I realized that the front door drags over the tile.. I have taken the area down to subflooring and have used 1/4 inch concreat board. The tiles are also about 1/4 inch thick. The frontdoor is metal
so shaving bottom is not an option. HELP
  • 670 Answers
The best way to solve this is to remove the door and re-install it at the desired height. Last resort - cut jambs off, raise the threshold. cut the top off the door, reblock it and move it up in the jamb. Yes, I have done this before, when there was no room to raise the door. I managed a door shop and we cut and reblocked many steel doors at the top. I like to use construction adhesive to hold the block.
Posted on Jul 22, 2009
How to replace the door blend actuator on 2009 lincoln mks
Right side or left ? Electronic Automatic Temperature Control or manual ? Temperature or mode door ?
Temperature Blend Door Actuator - LH Removal and Installation
NOTE: It is not required to install the new LH temperature blend door linkage parts included in the LH temperature blend door actuator service part kit if only the temperature blend door actuator requires replacement and the linkage parts are not broken or binding.
LH temperature blend door actuator and linkage
  1. Remove the 2 lower steering column opening cover bolts.
  1. Detach the lower steering column opening cover.
  1. Disconnect the in-vehicle temperature sensor aspirator hose and electrical connector.
  1. Position the instrument panel wire harness away from the LH temperature blend door actuator.
  1. Remove the 3 LH temperature blend door actuator screws.
  1. Disconnect the LH temperature blend door actuator electrical connector.
  1. Remove the LH temperature blend door actuator.
  1. Manually operate, and inspect the LH temperature blend door linkage for incorrect placement, binding or damage.
Temperature Blend Door Actuator - RH, Dual-Zone EATC Removal and Installation
NOTE: It is not required to install the new RH temperature blend door linkage parts included in the RH temperature blend door actuator service part kit if only the temperature blend door actuator requires replacement and the linkage parts are not broken or binding.
RH temperature blend door actuator and linkage
  1. Disconnect the glove compartment damper from the glove compartment.
  1. Remove the glove compartment.
  1. Remove the RH lower instrument panel insulator.
  1. Remove the RH lower floor console trim panel.
  1. Remove the 3 RH temperature blend door actuator screws.
  1. Disconnect the RH temperature blend door actuator electrical connector.
  1. Remove the RH temperature blend door actuator.
  1. Manually operate, and inspect the RH temperature blend door linkage for incorrect placement, binding or damage.
  2. Mode Door Actuator - Defrost/Panel/Floor Door
  3. Removal and Installation
    NOTE: The defrost/panel/floor mode door actuator can be accessed from below the driver side of the instrument panel.
    NOTE: It is not required to install the new defrost/panel/floor mode door linkage parts included in the defrost/panel/floor mode door actuator service part kit if only the mode door actuator requires replacement and the linkage parts are not broken or binding.
    Mode door actuator and linkage
    1. Remove the 3 defrost/panel/floor mode door actuator screws.
    1. Disconnect the defrost/panel/floor mode door actuator electrical connector.
    1. Remove the defrost/panel/floor mode door actuator.
    1. Manually operate, and inspect the defrost/panel/floor mode door linkage for incorrect placement or damage.
    Mode door actuator linkage only
    1. Remove the mode door linkage.
      1. Depress the tab and remove the panel door lever.
      1. Remove the floor/defrost door intermediate lever screw and floor/defrost door intermediate lever.
      1. Pull straight outward to remove the floor/defrost door lever.
    1. NOTE: When installing the mode door actuator, make sure that the panel door lever and floor/defrost intermediate lever are correctly aligned with the mode door actuator cam.
      To install, reverse the removal procedure.
Nov 10, 2016 | 2009 Lincoln MKS
Tip
Tips on how to Get ready the Subfloor intended for Ceramic Tile Installs
Ceramic along with porcelain tile are generally among the most rigid supplies intended for floors. They require the subfloor that's which will take into account that, without any fluctuation and also motion. If ceramic and also porcelain tiles are generally set up on the wrinkled surface area, a person manage the risk connected with allowing the tiles to be able to break and also loosen. Locations recommendations on tips on how to get ready the subfloor for a tile assembly.
one. The installation of ceramic tile along with porcelain tile with a real piece
Repair many splits along with wrinkled pads from the real subfloor before the assembly - specifically crucial in the event the tile will be becoming specifically bonded to the real.
If connected with subfloors along with great splits, look at the chance of removing a large portion of real piece along with replacing that using a brand-new one as an alternative to patching all the splits.
Intended for negative splits from the real piece, smooth that along with real filler, and also related substance.
In the event the real subfloor will be brand-new, that have to be still left to be able to treatment 29 days and nights previous to tiling.
Personal hygiene will be paramount. Aside from virtually any surface area supplies, you'll want to take away virtually any grease intrinsic and extrinsic stains, and also alternative contents that have tarnished the piece because most effective it is possible to.
Bare cement backer snowboard can offer powerful, flat working surface to put in tiles on for those who have the real wood subfloor.
only two. The installation of ceramic tile along with porcelain tile with a plywood subfloor
The plywood subfloor have to be structurally seem along with capable to help support the assembly. Tile floors are generally hefty along with tile is a very difficult substance. It is going to bust and also dislodge in the event the surface area bends less than the fill.
Don't forget which you are required an extremely flat working surface to be effective on. If desired, stone dust the plywood into level the subfloor.
Plywood have to be set up over an acceptable subfloor along with have to be a minimum of one 1/8? heavy if put together with the subfloor. Interior-grade plywood along with particleboard are not deemed strong sufficient for a tile assembly.
three. The installation of ceramic tile along with porcelain tile over plastic floors
Non-cushioned plastic along with linoleum which is structurally seem along with unencumbered with high motion can certainly take action just as one suitable subfloor.
Padded plastic seriously isn't the perfect subfloor. You need to take away the plastic ground along with virtually any remnant adhesive utilised to the plastic assembly.
In some instances, it is possible to eliminate the plastic once more, however , not the adhesive. Use the skinny placed which is endorsed from the backer snowboard maker.
If it seems hard, you might want to lay out the backer snowboard along with thinset.
several. The installation of ceramic tile along with porcelain tile over a pre-existing tile ground
It is possible to sometimes keep the tile ground set up along with employ thinset specifically over that, and also take away the tile using a hammer, dependant upon the best way high the ground must sit down relative to be able to doors and also other internal factors.
In the event the current tile ground is focused with a mortar mattress, it really is very difficult to eliminate the tiles with no removing beautiful mortar mattress.
If you're the installation of specifically on the older tile floors, uncertain " up " the existing tile along with stone dust document. Clean using a degreaser along with analyze a little community suddenly intended for bonding.
In addition, test the height from the ground while using height of doors along with showcases. Any good thinset enable you to set up the brand-new ground.
Incorrect to order subfloors
Subfloors in order to avoid intended for tile installs are generally those that are inclined to bend, increase, contract, and also warp. Virtually any high motion may loosen the tile along with soda the grout. Incorrect to order subfloors have to be succeeded and also taken care of using a suitable underlayment. Here's a list of no-go subfloors:
Padded plastic
Border set up plastic
One layered plywood
Flake snowboard
Particleboard
Computer chip snowboard
Hard wood (strip) floors
Luan plywood
OSB planks
Masonite
Linen steel
Which kind of subfloor considering the installation of the ceramic tile on?
Continue to searching for the ideal tile to your renovation venture? Please click here to be able to consider the amazing group ceramic along with porcelain tile.
Wholesale Ceramic Tile from China Manufacturer Best price
on Jul 31, 2015 | Building Materials
Arcylic shower base installed backwards
If it were mine... I'd kick myself several times (yeah, I've done stuff like that), then bring in a 4" angle grinder with a cutoff wheel. That would cut the flange MUCH faster - and generate far fewer sparks - than a belt sander. Work really carefully, though, and maintain really close control so the angle grinder absolutely stays level while you work. In fact, this would be a good spot to make up a special little jig to keep the angle grinder level and supported at one uniform height all the way across the door.
May 11, 2014 | Plumbing
Armstrong commercial flooring
Go to armstrong installation guides on the web, they should give you hints on things like cutting around door jambs etc. And yes you can score and snap. Make sure you get a heavy score into it though
Apr 04, 2014 | Armstrong 12" x 12" Intaglio Gray Speckle...
I am wondering what cork flooring is. I am needing to fix something with my floor and someone told me I needed a new cork flooring. I don't understand.
I am not sure what flooring you have at the moment but sounds to me like someone is trying to sell you something. IF you already have cork flooring then it can be repaired, get another opinion from some other company. cork flooring comes in tiles that are laid down like other tiles with glue, it is recycled cork that has been compressed/glued/heated into flat hard sheets then cut into tile squares kind of like particle board. inexpensive and soft under the feet, good insulter as well. hope this gives you some clarity. always get a second opinion. take care, good luck.
Oct 15, 2013 | ORIENTAL FURNITURE Practical Office...
Slate bathroom tile
First clean floor down to plywood. Then buy mastic, notched trowel and tile spacers from hardware store. Lay out tile in the pattern you want by cutting them with a tile saw you rented. take out dry laid tile and mastic a small area and install til making sure you press the tile into mastic. Insert spacer and install next tile.
May 16, 2013 | Home
Can ceramic tile be installed over old ceramic tile?
You can install tile over tile. However here are the risks. The new tiles will require at least 3/16" of tile adhesive UNDER the tiles when put in place after they have been pressed into position. Additionally the trim around the tiles willhave to be removed and elevated the distance of the tile thickness and the 3/16" grout distance. The tiles if on the second floor of a home will easily losen due to the expansion and contraction of the home and the difference in the 2 types of tiles expansion and contraction rates.
It is not difficult to remove old tiles. You use a flat bar type scraping tool and the old tiles usually will pop right up off the floor. You will have to break maybe 2 tiles to get started but after that they are easy to remove.
My experience in my own fully tiled in all rooms 2900 sq ft home in the tropics is that I have to remove the old tiles as over time the new tiles losen on top of the old tiles. I have tried it several times and have had at least 1 tile come loose each time.
Thanks for choosing FixYa,
Kelly
Oct 05, 2010 | Home
1 yr old lg dishwasher model# ldf6810st LEAK/CONDENSATION
TOO ALL SAMSUNG LDF AND POSSIBLE OTHER LG DISWASHER USERS:
LG NEGLECTED MY CALLS TO SOLVE THIS PROBLEM. THE DRIPPING PROBLEM FROM THE CORNERS OCCURS:
1- VENT ASSEMBLY FOR HOT AIR BLOWER SEAL LEAKS: EASY TO FIX JUST USE A GOOD QUALITY CAULK AROUND THE SEAM. YOU WILL HAVE TO DISMANTLE THE BLOWER ASSEMBLY WHIXH IS FAIRLY EASY.
2- THIS IS VERY IMPORTANT: LG HAS A DESIGN FAULT. WHEN THE DISHWASHER FILLS WATER AND STARTS PUMPING TO SPRAYS THE AIR INSIDE THE DW HAS NO WHERE TO GO THEREFORE THE WATER WAS PUSHED UNDER THE BOTTOM OF THE DOOR GASKETS (THE ONE ATTACHED TO THE DOOR BOTTOM, NOT THE ONE AROUND THE MAIN CABIN). SO AIR WITH WATER PUFFS OUT OF THE PAN HITS THE DOOR AND LEAKS DOWN. THE SOLUTION IS TO LET THE AIR OUT SOMEHOW. YOU MUST TRY TO PUSH-IN THE DOOR GASKET WHICH IS SEALING LEFT/RIGHT/TOP PART OF THE CABIN AND THE DOOR. IF YOU PUSH TOO MUCH THE WATER MAY LEAK FROM THE SEALS SO BE CAREFUL NOT TOO PUSH TOO MUCH. BASICALLY TRIAL AND ERROR. YOU CAN DO THAT AFTER YOU REMOVE THE DOOR COVER. THE LEAKAGE OCCURS IN THE BEGINNING OF THE CYE SO IT IS FAIRLY EASY TO TRY. IF THAT IS NOT A SUCCESS THEY DROP OF CAULK ON THE ONE OF THE DOOR EDGE TO PUSH THE GASKET SO THAT THE DOOR PUSHES IN THE GASKET TO ALLOW AIR OUT RIGHT AROUND THE CAULK. NORMALLY DISHWASHERS HAVE AN ELECTRICALLY ACTUATED OUTLET TO LET THE AIR OUT. THEY JUST WANTED TO SAVE COST AND HAVE US DEAL WITH THIS RIDICULOUS PROBLEM.
Feb 05, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
170 people viewed this question
Top Dishwashers Experts
Owen Barnes
