Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Scanner problem When I click on scan documents, no printers are listed when it says to choose kodak printer. My printer is connected, and it does work when I print.
  • erikzirkle Jul 22, 2009
    Re-installed software, still having the exact same problem.
    Problem Solver:
  • 8 Answers
Perhaps the scanner portion of your software has become corrupted. Re-install the printer software and it should work fine. If you don't have the printer software, you can find it here....
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=12667&product=EKN034524
Posted on Jul 22, 2009
KODAK ESP 3200 SERIES WILL NOT SCAN
I had the same problems; missing Icon and 100-2105.
This solution on the Kodak web site solved my problem.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Jan 13, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
How to use the *2670 lexmark scanner
Please follow the steps below on how to scan using your Lexmark X2670 printer:
Using the printer control panel
1. Open the top cover, and then load an original document face down on the scanner glass.
2. Close the top cover to avoid dark edges on the scanned image.
3. Make sure that the printer is connected to a computer, and that both the printer and the computer are on.
4. From the printer control panel, press the scan button.
5. Follow the instructions on the computer screen.
Using Windows
3. Do one of the following:
• In Windows Vista, click > All Programs, and then select the printer program folder from the list.
• In Windows XP, click Start > Programs or All Programs, and then select the printer program folder from the list.
4. Click Lexmark Productivity Studio.
5. On the main screen, click Scan.
6. Follow the instructions on the screen.
Using Macintosh
3. From the Finder desktop, double-click the printer folder.
4. Double-click the 2600 Series Center.
5. From the "What is being scanned?" list, choose the type of document to be scanned.
6. Click Scan.
Source: Lexmark X2600 Series User's Guide
Oct 09, 2011 | Lexmark X2670 All-In-One Printer
Keep getting error message 100-2105 when I try to scan
I had the same problem. The icon disappeared. Then the 100-2105 error message came up.
The solution on the kodak web site worked for me.
From
Scan a document.
Sep 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Im trying to scan a document but its saying error code 2106. i have it hooked up through wireless
Try these things:
1. place a doc to scan in the scanner. Close the lid and hit MENU, COPY document, START.
If that doesn't work you'll need to contact kodak. If it does then try this next:
2. Check for ADMINISTRATOR rights.
  1. RIGHT CLICK on the kodak icon and select Properties > Compatibility tab > Run this program as an administrator
  2. Select RUN AS ADMINISTRATOR
  3. click APPLY
  4. click OK
Then try scanning again. If it still doesn't work then-
Reload the driver:
  1. select Start > Run.
  2. Type %windir%, then click OK.
  3. Double-click twain_32.
  4. Right-click Kodak, then select Delete.
  5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to (cd drive: > printer > scanner.
  6. Then go to cd drive: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
  7. Open Home Center Software
  8. Select Scan Documents and Pictures.
  9. Scan a document
If it still doesn't work then you'll need to take it in for service.
Jun 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do i scan a document from kodak esp3 from printer to my computer
Click on the kodak aio icon or program file. From there you can choose to scan if your button is not working. Also most OS will have listed in the control panel a link for devices and printers. Depending on your OS you should be able to click on your printer and then choose to scan a file from there as well!
Jan 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP5 AiO Unable to scan to PC. Error code on opening Scanner 2106 Please advise,THANK YOU!
Please clarify a few things for me so I can help you solve this issue.
Are you trying to scan from the printer to the computer? (pushing the scan command on the printers keypad to send the signal to the computer)
OR
Are you trying to scan from the computer to the printer? (Using the scan options in your software by choosing "start" and then "programs" and opening your printers software to choose the scan option)
If your scanning from printer to computer (using the printers scan option on the keypad) and your getting an error code, chances are the problem is you have not set up your defaults in the printers menu yet. To scan from printer to computer, the printer needs to know which program you want your document to scan to in your computer. If its a text document, some people choose "Microsoft Word" and the scan fuction sends your item to that program and opens it for viewing on your computer screen.
There are different programs to use for each type of fax that need to be set up in advance in your printer to be able to scan from printer to computer. Send pictures to a photo editing software and choose the size and resolution you want as "default". Do the same for setting up text documents before you try and use this feature to eliminate the error code.
To configure your options to scan from printer to pc, push the "menu" button on your printer and use the up and down arrows on the printers keypad to move through the choices. Find the command similar to "scan options" and follow the prompts to set the defaults on handling text documents and pictures and then save your choices by pushing the "ok" button on the printers keypad.
Try scanning again with your computer turned on and open to the desktop. Push the scan button on the printer and see if it sends the image or document to your computer screen. It should warm up, then scan and show a preview on your screen for you to accept or reject. If this does not happen, please asnwer my questions as listed above and clarify what you see so I can help solve this issue right now.
Sep 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a Kodak AIO 5 printer and Windows 7. I
This is easily accomplished using Kodak AIO Home Center v5.3:
Scanning documents from Home Center
1 On the main screen, click Scan Documents and Pictures.
2 Place your original document face down on the scanner glass.
3 Select Document.
4 Select the type of document you are scanning.
5 Select a Resolution for your scan from the drop-down list.
6 Select Perfect Page Technology to automatically correct imperfections in the scan.
7 Select Next.
8 On the Edit screen, edit each image as needed.
9 Click Next.
10 Select Save to File, then select Save As (pdf or rtf), Then Save.
11 Select Done to return to the main menu.
Jul 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Scanner will not work have just purchased the printer and have now got the print working but cannot get scanner working ?
scanning anything will ask for a place to save the document install kodak home center from cd or from net- www.kodak.com/go/downloads connect ur printer and computer with usb 2.0 open home center on computer
and try to scan a document by placing on scanner glass on the printer will be able to scan if not, call kodak 1800 419 1909 for further directions
Jul 08, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Scanner not detected by Microsoft Office Document Scanning
1) Install the Microsoft Office Document Imaging feature by following the steps
given below:
1) Go to Start -> Control Panel.
2) Click the Add or Remove Programs.
3) Select the Microsoft Office Professional Edition 2003 and click the Change
button.
4) Click the Add or Remove Features and click on Next.
5) Select the Choose advanced customization of applications checkbox and click
Next.
6) Click on the Office Tools -> Microsoft Office Document Imaging -> Scanning, OCR
and Indexing Service Filter.
7) Select Run all from My Computer, insert the Office installation CD, and the
feature is installed.
Jan 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
59 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
