Question about Microsoft MechAssault 2: Lone Wolf
Xbox Mech assault 2 lone wolf Limited Edition wont start
When i pop the game disc into the drive, the xbox will freeze for a bit like its having trouble reading. but the disc has virtually NO scratches or smudges. and it will give me the "the xbox cannot read the disc you inserted, please make sure it is an xbox game or dvd disc, and that it has no scratches" message. i installed the maps update pack that came with it (limited edition disc pack) when i first played it. so when it stopped working i deleted the map pack and it didn't help. =(
    Problem Solver:
  • 5 Answers
Have you tryed actualy cleaning the xbox lense by running a lense cleaner ? your supposed to clean any lense that reads discs after every 10 hours of play time because of the dust thats getting collected .
Posted on Jul 22, 2009
GAMES GOT STUCK IN THE XBOX 360 HALO EDITION THE 3RD TIME i USED IT
It needs a new drive chassis, you will have broken the little plastic tabs that hold the tray level and straight! you can replace the drive but the new drive will need either the old logic board off the broken drive fitted to the new drive or the dvd key dumped off the old drive and flashed to the new one to make it work.
Dec 23, 2012 | Microsoft Xbox 360 Halo 3 Special Edition...
My 360 will let me play a little bit of a game at a time. after playing maybe 5 or ten min or so it will freeze up. the last two times that it froze up it asked me two clean the disc, or contact xbox3660...
You specify the xbox 360 do you know what year model you have? If it as earlier model then likely you are running into system instability with many reasons for the error being possible.
Does the error only appear with one particular title or across your game library?
If it is just one game then attempt to install the game onto your hard drive and play the game after that. To install the game onto your hard drive you will need to do the following:
Install Xbox 360 games on your hard drive from a game disc Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
  1. Insert the game disc into the disc drive.
    Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
  2. From the Xbox Dashboard, go to My Xbox.
  3. Select the game you want to install.
  4. Press Y on your controller.
  5. Select Install to Hard Drive.
    A progress indicator appears while your game is being installed on your hard drive.
Notes
  • Installing an Xbox 360 game might take several minutes.
  • Multidisc game? Install each disc to your hard drive.
Jul 18, 2011 | Microsoft Xbox 360 Console
My sons have a limited edition halo green xbox but it wont read discs just says open tray.I then bought one of a friend and thats not working i plug it into the tv but it comes up no signal.I have 2 bored...
Fastest way would be install drive from no signal xbox to the halo edition
reg xbox drives are swappable
there are about 6 torx screws on bottom and 1 on the hdd tray 2 on drive holder not a very difficult fix
Aug 03, 2010 | Microsoft Xbox 360 Console
Game wont read says put disc in xbox 360 but i am using xbox 360 also it says its a dvd not game just wont let me play no more
If you have recently tried to mod your Xbox 360 then you did not get the drive key installed correctly. Otherwise the laser lens is either dirty/ starting to weaken. You can either replace the laser lens in the disc drive, try to clean it, try the POT tweak or replace the whole disc drive. Keep in mind if you replace the disc drive you will need to swap the PCBs or the drive keys. Hope this helps.
GATpro
May 21, 2010 | Microsoft Fable 2 for Xbox 360
When im trying to play my regular xbox it flashes red and yellow
If the XBOX does this before it even starts up, you have probably got a bad hard-drive. Your best option would be to try a game that does some kind of dashboard update. ( Splinter Cell, Mech Assault, 007 Agent under Fire, Ninja Gaiden Black?, Google for a list) A dash-board updating game, should bypass the start-up process and attempt to reinstall the dashboard.
If that doesn't work, your xbox will need a professional repair.
Mar 01, 2010 | Microsoft Xbox Console
Xbox wont play game
probly a broken dvd drive?
May 09, 2009 | Microsoft Xbox 360 Console
Won't load to main menu...
Is it the limited edition disc? does it show a movie and maps update menu? If it it, you're using the Limited edition extras disc, not the game disc. if you got 2 discs with it, (diffrent colors) use the other.
Hope that helps =)
Apr 18, 2009 | Microsoft MechAssault 2: Lone Wolf
My new xbox just got it for christmas is freezing
Right, lay your Xbox360 down dont keep it upright, try installing COD4 to your hard drive then once installed go into you game library and click on cod4 and click play from hard drive ( and if you dont know how to install games to the hard drive make sure your xbox isnt on automatic start when a disc is inserted and put the disc in and when it says play cod4 press Y and then click install to hard drive) hope this helped....
Feb 07, 2009 | Microsoft Xbox 360 Console
Microsoft MechAssault 2: Lone Wolf Logo
457 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
