Question about Ovens
Markings rubbed off oven and hotplate controls of stove
Hoping to get a manual for Simpson Nova electric upright stove - approx 10 years old. Has four solid hotplates, grill in oven.
All markings on control knobs have rubbed off so impossible to set oven temperature, grill or hotplates accurately.
barkencoa
  • 3463 Answers
SOURCE: griller on simpson harmony nova oven
In my experience, it is normal to leave the the door open when grilling, otherwise it is liable to cause the bakelite handle of the grilling pan to get very hot, and possibly melt or catch fire, and make it to hot to hold the handle.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
  • 327 Answers
SOURCE: Simpson Harmony Nova Thermaflow Oven (63B906W) won't heat up
Hello,Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Posted on May 26, 2010
  • 24 Answers
SOURCE: We have moved into a new (old) house, and don't
sounds like the main gas line to the oven was shut off. you need to locate the line and look for the valve and turn in on.
Posted on Aug 13, 2010
caroldon
  • 17129 Answers
SOURCE: I HAVE A ELECTRIC TECHNIKA
The important test is to check the continuity of the heating coil to see if the coil is good, If so check the power supply to the coils, it can be faulty due to poor switch, a poor temperature control or a faulty lead.
Please check and respond
Posted on Oct 05, 2010
  • 1536 Answers
SOURCE: Question from electricain with long
I wonder if L1 and N are reversed, at least for this hot plate. The readings you get are consistent with a switched neutral and always-connected L1. This is not permitted in any electrical code I know.
If you get a constant 240 V at "terminal 1" referenced to "terminal 2", but no heat, and the resistance is consistent with a 1400 W heater when it's cold, I'd suspect a heater terminal or the element itself is opening up when it gets warm. If you have a means of measuring current such as a clamp-on induction ammeter, you may see an initial current up to 6 amps, then a quick drop-off to zero, random fluctuation, or cycling on and off. That would confirm my hypothesis.
Posted on Feb 07, 2011
Need illusrated wireing diagram for 18 year old defy gemini petit chef electric stove
Oven:
power comes in, goes to overtemp > timer > function switch > thermostat > element then back to neutral
fan & light come on with function or thermostat switch.
what else do you need to connect?
Oh, hotplates. Power in > infinite switch > hotplate and indicator then back to neutral.
Watch out for two phase with indicator light.
Oct 18, 2013 | Ovens
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
I have a es400 stainless steel stove. my right front burner stays on. please help .
You have a problem with the hotplate controller. The controller is faulty and requires replacing. The controller can be accessed by removing the panel behind the controllers.
Apr 01, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I will soon purchase a GE Double Oven (no stove top). I need to know what amperage I need to wire my kitchen for. 30? 40? 50? thanks.
A full upright range including 4 hotplates, oven and grill elements is generally rated about 8.0 to 10.0 kilowatts. The normal circuit in Aust. is a 32 amp circuit. Check the kilowatt rating of the double oven but I don't think it will be any higher than 6.0 kilowatt. If so the 30 amp circuit will be fine.
Feb 18, 2011 | GE Profile JTP56 Electric Double Oven
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Looking for manual simpson nova 63538
how does the clock work an how do you reset it
May 13, 2010 | Ovens
Code : E3 -F1-
I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Aug 19, 2008 | Ovens
Ovens Logo
167 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
