Question about Sabre LCT371BKA LCD TV
Program Code for direct tv remote control
I have 42" Sabre LCD TV and I'm trying to program my Direct TV remote in order to use volume control and there is no code in the manual. Please Help!!!!!!!!!
  • Marnin Somerman
    Marnin Somerman May 11, 2010
    Which DirecTV remote do you have?
SOURCE: Cannot pmy "Direct TV Satellite Remote, so I can control TV Sound
10178 or 11331 or 11610, depending on the model of your remote.
Posted on Sep 24, 2009
dsacco86
  • 1077 Answers
SOURCE: cant program direct tv remote with my new sylvania lc320slx
The remote is only programmed with only so many codes. Sadly, It doesn't hold all code for every TV made.
But you can try making the remote search every code stored inside to see if one of them will work.
Here are the instructions form the DIRECTV web site:
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Posted on May 18, 2009
SOURCE: Need a remote code for the tv 37" Sabre LCD Tv Model # lct371bka. RCA Universal remote Model # RCR660
as soon as u bought the universal remote it came with a paper that say a bunch of codes find ur tv model go to set up look were u can put in the code and follow the code exact
Posted on May 24, 2009
  • 20 Answers
SOURCE: I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
Posted on May 30, 2010
gregs_rockin
  • 274 Answers
SOURCE: remote control codes for sabre tv
When are you people going to learn. The only way you will get it to work is to find the same remote that come with the tv, That is what happens when you buy unknown brand (Electronics) Not evan a good universal remote will work on them, Stick to a known brand.Like jvc,sony, toshiba,lg,panasonic. Then you won,t have that problem. If the dog ate your remote,Because you for got to (Feed) it.
Posted on Oct 21, 2012
Element 32 in tv
Element 32 in tv - Fixya
www.fixya.com > Forum > Flat Panel Televisions > Element
38 mins ago - element 32 in tv Need a code to run the volume and on off shaw direct sat. - Element Flat Panel Televisions question.
Remote Control Code for Element LCD TV -- & Direct ... - Fixya
www.fixya.com/support/t1101060-remote_control_code_element_lcd_tv
Remote Control Code for Element LCD TV -- & Direct TV Haven't been able to find the right code to program the - Olevia LT32HVM 32 in. ... It is annoying to turn the TV on and the volume with the Element remote and then have to use the ..... Need the codefor a 42 inch LCD TV model ELDTW422 to program our Direct TV ...
Element 32" 1080p TV (ELDFW322): Unboxing & Setup ...
? 6:40
https://www.youtube.com/watch?v=EKtjBnx6EG0
Mar 27, 2013 - Uploaded by PureLegit
This is a new video on this TV that I got from Element. If you go back on my channel you will see my first ...
Jan 20, 2016 | Element Televison & Video
Programming my remote control (which is a dish network remote control) to operate my 42" sanyo LCD
In order to program the remote to a TV set, hold the clear "TV" button in the upper left hand corner four four seconds or until all four of the mode buttons light. Next press in one of the three digit codes below followed by pound (#) Remote codes: 590, 683, 720, 591, 543, 593, 813, 542, 533, 652, 726, 611, 500, 503, 627, 661, 956, 591, 694, 666, 252 After trying each code press the volume and power buttons, if they control your TV set be sure to press the "SAT" button.
Daniel Busa
DISH Network
Customer Service
Aug 28, 2011 | Sanyo 42 in. LCD TV
My remote does not turn on the tv and control the volume. Can you give me some codes to try for a vizio tv?
From the user manual,for 5 digit remotes (like most Direct TV units) use codes 11758 and 10178, then 01377, listed in order of preference. For 4 digit remotes use 1758, then 0178. For 3 digit remotes (Echostar or Dish Network) use code 627
Oct 01, 2009 | Vizio VW42LF 42 in. LCD HDTV
I just installed direct tv and their remote wont let me change volume. if I use the tv remote I lose the programming. Need a code so the tv can be controlled by direct tv's remote.
Hi, post the direct TV remote # and the box model # so I can lookup the info for you. you probably already know directTVs remote programming is built into the menu (codes and all).
You did not mention if the DT remote powers the TV on or off?
post more info if you still need help and I'll try
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Sep 04, 2009 | Proscan 42LA45H 42 in. LCD TV
Program code for olevia 37 to direct tv remote
the remote control code for DirecTV with Olevia 242T or 237T (37' or 42') model is 11610. this code will power on/off and volume up/down the buttons on directv remote.
Or buy the Olevia RC-LRN remote control. go to olevia.com - accessories - remotes.
Mar 15, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Direct TV remote does not control TV on/off or volume.
hi! i have here a couple of codes for your tv, just try them, 1468, 1004, 1011, 1013, 1025, 1028, 1031, 1033, 1036, 1044, 1045, 1080, 1097, 1101, 1102, 1107, 1382, 1383, 1483, 1484, 1512, hope this helps!!!! goodluck!!!!
Feb 06, 2009 | Emerson LC320EM9 32 in. LCD HDTV
I have the same setup like you. Direct TV and Emerson LCD TV. The Direct TV remote stores a limited amount of codes and none worked on my TV. Sadly it's not something you can update. They seem to only stick with the popular codes. Welcome to the "head of the curve" like me. lol
Jan 04, 2009 | Televison & Video
Cannot find the code for a Sabre Model No. LCT320BKA television
I have a comcast universal remote and can't find remote code for plasma 42" lcdtv.pls help
Nov 23, 2008 | Televison & Video
Remote control code
hi
you can download your manual here for the colossal universal remote.
since ilo tvs dont seem to have a specific code, you can either try the generic codes that are found here in the pdf manual.
hope this helps
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=livingsolutions&dv=universalremote&md=colossal3in1606426&kw=&st=&ar=&dt=&so=&pg=1&file=others/living_solutions/colossal-manual.zip
Jan 22, 2008 | Spectroniq PLTV-42HW68 42 in. LCD TV
Olevia 32 inch monitor with direct tv box
Dec 25, 2007 | Directed 434MHZ Remote Control
Sabre LCT371BKA LCD TV Logo
1,158 people viewed this question
Top Sabre Televison & Video Experts
Tom Chichester
Are you a Sabre Televison and Video Expert? Answer questions, earn points and help others
